Canon ir3025 image problems
  • kuby
    • Oct 2007
    • 1400
    Have a Canon ir3025 that has a light image on the rear side . When the copy comes out the image toward the back of the machine is very light. Have changed the developing unit (it help for a little while and then comes right back), changed the drum, transfer roller, toner. Anyone seen this before? Tech said he cleaned the laser unit and it still has the same issue.
  • teckat
    • 16083
    Re: Canon ir3025 image problems
    If the image on the drum is good but faint on the paper, the problem may reside in the transfer section of the copy process.
    Re-seat transfer roller and confirm correct pressure.
    Another possible cause is when the developing assembly is not receiving correct cam pressure.
    was this a new developer unit ?/it must have a good magnetic brush which is even across the entire surface.
    image density is light on the rear side of the copy.
    In this case> transfer roller was not properly attached to the mounting bracket. The transfer roller was removed and repositioned in the bracket working free the bind within the bracket.
    In this case, the transfer roller, spring and bracket were replaced.
    Check the front and rear transfer arms for proper positioning..
    When positioned properly, each end of the transfer roller should "spring back" after being pressed.
    If the roller is not positioned correctly, check that the springs on each end are in place.
    note:
    When there is a bind from a metal roller in a plastic bracket, it is recommended to replace the plastic part as it may have been damaged and allow the symptom to return.
    another thing to check >
    is checking &
    cleaning toner from the slit glass located on the scanner laser assembly
    • Rachid.Akli
      • Oct 2011
      • 595
      Is you issue common to copying and printing (if the machine is not a printer, print a report or a pprint) ?
      Rachid
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • campy
        • May 2012
        • 315
        Try cleaning the slit glass in front of the laser unit there may be toner on it. You need to remove the drum to see it.
        • canonbundy
          • Jun 2012
          • 607
          As Rachid Posted check internal print - if only occurring on copies clean Scanner Unit, if occurring on both and still doing after all other checks, maybe push the lower R/H side of the door in as a copy is made, sometimes the hinge can be bent.
          • jose antonio
            • Dec 2012
            • 119
            Remove the developing unit and inspect the magnetic roller, toner layer on the roll should be equally distributed front to back.
            If not, you have a toner supply problem. If ok than look into optics & laser scanner area and transfer.
