canon imagepress 6000 vp copy of waves / lateral extension
  • friedrich
    our brave canon technicians changed many parts but the problem still exists. it occurs already in the first fixing unit.
    to much heat? is there any manual about the heat in the fixing unit in generell and specially in FixEX C and FixEX E? why is the heat there about 50 degrees higher than at Fix C and Fix E?
    are there any rollers which needs to be replaced which are not listed as spare and wear parts?
    or in general: what is wrong with the fixing unit.
    if you see a chance to help us to solve the problem with the image press 6000VP. even elemental / basic advices would be appreciated.
    thanks in advance for your replys
    friedrich
  • johnyb
    • Feb 2011
    • 167
    Re: canon imagepress 6000 vp copy of waves / lateral extension
    Originally posted by friedrich
    [ATTACH=CONFIG]18701[/ATTACH]
    friedrich
    Hi Friedrich
    Eliminate the paper with a new batch, make!
    Can you stop the paper before the fuser area, is it ok?? if so go to fuser.
    If you put plain paper throught the machine and dont slect gloss, does it still do it?
    if so presumably it is the primary fuser...
    Have all the parts listed below been changed????
    How are the fuser drive gears, they crack!!!
    SUB UNIT Part Description QTY Part N0
    Upper fuser Uper Fuser Roller 1 FL2-6945-000
    Bearings 2 XG9-0419-000
    Bushings 2 FB4-3689-000
    Lower Fixing Belt 1 FL2-6530-000
    COVER, PAD 1 FL2-6259-000
    Oil 1 FL2-5453-000
    PRESSURE PAD ASS'Y 1 FM3-7601-010
    Thermistor FK2-3094-000
    Web Web 1 FC5-9778-000
    Sensor Arm 1 FC6-1294-000
    Web Roller (Orange) 1 FM3-1649
    ROLLER, HEATING 2 FC7-0932-000
    EXTERNAL HEATING CLEANING ROLLER ASSEMBLY 2 FM3-1647-000
    ASSEMBLY Thermistor Assy 1 FK2-3097-000
    Thermostat 2 FM3-0657-000
    Good luck!
    • friedrich
      Originally posted by johnyb
      Hi Friedrich
      Oil 1 FL2-5453-000
      Good luck!
      hi johnyb,
      tjs for your reply.
      we controll hunidity. we tried new and certified paper even with an oce canon paper specialist. same results. even 300g paper show similar results.
      paper is ok before it moves thru the fuser.
      we didn`t try plain paper but with little color on. both sides coated and gloss minus 2. thats the lowest temperatur er can get.
      fix Fix C and Fix E temperatur around 150 degree FixEX C and FixEX E temperatur around 200 degrees. what is FixEX C and FixEX E? very little better in general still same results.
      since we have a service contract with canon europe we can`t work on the machine by ourselves. i will ask them tomorrow. i hope they will answer. our board book does not tell everything.
      i expect no answer before next week.
      kind regards
      friedrich
        • 16083
        is tech trained on this series ????????????????????????
        any jamming is this happening before fixing
        did tech work on fixing unit
        FIXING.pdf
        if after fixing---see below
        There are 3 decurlers with this machine. Each decurler is controlled according to the media setting information (media type/size) and the video signal (image density) to remove curl of the paper.
        [1] Bypass decurler
        [2] Duplex decurler
        [3] Delivery decurler
        Decurler pressure can be switched in User Mode.
        System Settings > Device Management Settings > Degree of Curl Adjustment
        In service mode >
        COPIER > Option > BODY > IMGC-ADJ, change the setting from '0' (default) to '1'.
        Reference: IMGC-ADJ is used to switch the display mode of the image adjustment items used by the system administrator. Setting this to '1' will display the following items: curl correction level adjustment, paper separation fan level adjustment, image location adjustment, secondary transfer voltage adjustment, and gloss adjustment.
        U may need to have the tech remove these decurl units to inspect & clean rollers
        "Curl Correction for Each Paper Source" is displayed when setting
        COPIER> OPTION> BODY> DCL-SW to 1.
        COPIER> OPTION> CST
        D1-CURL Setting of curl correction at pickup from Right Deck
        D2-CURL Setting of curl correction at pickup from Left Deck
        D3-CURL Setting of curl correction at pickup from Side Paper Deck
        D4-CURL Setting of curl correction at pickup from POD Deck (Upper)
        D5-CURL Setting of curl correction at pickup from POD Deck (Middle)
        D6-CURL Setting of curl correction at pickup from POD Deck (Lower)
        D7-CURL Setting of curl correction at pickup from Secondary POD Deck (Upper)
        D8-CURL Setting of curl correction at pickup from Secondary POD Deck (Middle)
        D9-CURL Setting of curl correction at pickup from Secondary POD Deck (Lower)
        D10-CURL Setting of curl correction at pickup from Multi-purpose Tray
        • friedrich
          • friedrich
            hi teckat,
            the tech is trained but from time to time they need support from other techs.
            no jamming. not happening before fixing.
            fix temp. light paper both sides coated. gloss minus 2. Fix C and Fix E around 150 degrees FixEX C and FixEX E around 200 degrees.
            will check curl correction and ask tech.
            tks again
            kind regards
            friedrich
            • friedrich
              hi teckat,
              we checked the board book and yes tech did work on the fixing unit but not clear what they did. and this is about the beginning of the paper destruction. at that time a second tech had to come to solve the roblem.
              regards
              friedrich
              • friedrich
                hi johnyb,
                i`m still not shure wether you got my reply. so one more time.
                yes we started with new paper. we controll our humidity. even a OCE canon paper specialist came and tried different papers. all with similar results.
                paper is ok before the fuser.
                we didn' try plain paper but with little color. we print with both sides coated and gloss minus 2. temperatur of Fix C and Fix E is about 150 degrees FixEX C and FixEX E shows about 200 degrees. we will check with canon what parts has been changed. due to the holidays we don't expect an answer before mid of next week.
                kind regards
                friedrich
                  • 16083
                  hi teckat,
                  regards
                  friedrich
                  so all is well ????????? /
                  posted a fixing unit pdf for u to download & keep by printer if needed by tech
                  • friedrich
                      • 16083
                      Sorry about that /// here are the repaired PDF's
                      Fixing System.pdf
                      • friedrich
                        hi teckat,
                        welcome in 2013. to keep you informed. there is no answer from canon germany till this moment.
                        kind regards
                        friedrich
