our brave canon technicians changed many parts but the problem still exists. it occurs already in the first fixing unit.
to much heat? is there any manual about the heat in the fixing unit in generell and specially in FixEX C and FixEX E? why is the heat there about 50 degrees higher than at Fix C and Fix E?
are there any rollers which needs to be replaced which are not listed as spare and wear parts?
or in general: what is wrong with the fixing unit.
if you see a chance to help us to solve the problem with the image press 6000VP. even elemental / basic advices would be appreciated.
thanks in advance for your replys
friedrich
friedrich
