IR 6000 ERROR CODE FIX?
  • ybnews
    • 94
    I cannot re-set my error code E000005-0000
    Tried several times.
    Here's what I do...
    *28*
    COPIER
    Screen flashes
    *FEEDER* 1/1 < ERROR >
    FEEDSIZE -----
    No on screen options are available
    Any suggestions on what to try next?
    Thank you in advance.
    Dana Lewis
  • montana
    • Aug 2008
    • 392
    Re: IR 6000 ERROR CODE FIX?
    Here's what I do...
    *28*
    COPIER
    Screen flashes
    FEEDSIZE
    Dana Lewis
    hi....try this...*28*copier>function>clear
    but you have a malfunction in the fixing web.....good luck
    • dan7777
      • Dec 2012
      • 680
      Here's what I do...
      *28*
      COPIER
      Screen flashes
      FEEDSIZE -----
      Dana Lewis
      Try and reboot and immediatly go to *28*. Replace the web if low. There are two counters to clear. COPIER>COUNTER>MISC>FIX-WEB and COPIER>COUNTER>DRBL-1>FIX-WEB.
      • ybnews
        • 94
        I tried that as you instructed. No go.
        Here's what's happening...
        I hit *28*
        Then COPIER
        Display screen appears with highlighted options below.
        I can get into those highlighted options.
        However, Display options across the top row are not responding to my touch.
        Therefore, I cannot get into "Counter" or any other functions in the top row.
        I suspect an issue with the touch screen.
        Any other suggestions?
        p.s. I checked the cleaning web. It is about half used up.
        Thanks.
        • vigour
          • Aug 2010
          • 1038
          Your touch panel is out of adjustment.
          You cannot clear the code until the panel is calibrated or replaced.
          Follow the instructions below.
          http://www.copytechnet.com/forums/ca...ay-5870-a.html
