wrinkle in A3 size only in IR 3025
  • mido
    • Nov 2011
    • 177
    Hi,
    Merry Christmas to all,
    I have a problem in IR 3025 with finisher S1, the machine in A4 size working very well but when copying on A3 size from the cassette or from the bypass tray, the paper wrinkles in the end of the sheet but no jamming occurs, only wrinkle,
    I changed the pick up, feed, separation rollers & fixing film assy, but nothing changed the wrinkle still occurs,
    plz let me know your opinion about this,
    Regards
  • ernesto
    • Oct 2011
    • 430
    Re: wrinkle in A3 size only in IR 3025
    Originally posted by mido
    Hi,
    Regards
    Hi,
    you can try to adjust this.... Level 2: copier > adjust>fixing> fx-fl-sp (+3)
    http://www.copytechnet.com/forums/ca...tml#post279158
    all the best
      • 23008
      Worn pressure roller and bearings is a possibility. =^..^=
      • mido
        • Nov 2011
        • 177
        Originally posted by ernesto
        Hi,
        all the best
        Hi
        Merry Christmas
        thank you very much the problem solved by change the fx-fl-sp to +3.
        but can you explain this fx-fl-sp what is the function of this if change the value from 0 to +3.
        what it means??
          • 23008
          Hi
          Merry Christmas
          what it means??
          FX-FL-SP is a fine adjustment of fixing film rotation speed, as can be seen on pg 16-43 of your service manual. =^..^=
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            The rotation cycle of the fixing film is monitored to control the fixing motor to a specific speed.
            When the fixing film rotates and, as a result, the reflecting member positioned in the loop of the film approaches the speed sensor, the machine detects the rotation
            of the fixing film.
