Ir5065
  • copicatt
    • Nov 2008
    • 366
    [CQ] Ir5065
    I have an image runner 5065 that is creasing the paper. I haven't been there yet but customer say is it only does it when doing 2 sided copies. I first assumed lower bearings but has anyone seen wrinkling only doing 2 sided? I am still leaning toward lower bearings. There is an image inside the wrinkles so this tells me that paper is straight passing under the drum. She says the copies are not skewed either. Just looking for input as i cant be there until monday....thanks all!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Ir5065
    She says?? Take a look first.
    • northernlife
      • Sep 2011
      • 847
      Re: Ir5065
      That is, what she said :-)
      • COPIERTEC ASSOCIATES
        • Aug 2011
        • 279
        Re: Ir5065
        When on site,observe the following:
        -check on the heater roller bushings,
        -check on the lower roller bearings and the lower roller itself,
        -check on the corona wires on the transer corona assembly in case they are old replace.
        Good luck!
        • mts777
          • 20
          Re: Ir5065
          Also, check the entrance guide to the fuser. Toner build up can cause the paper to skew before entering the fuser and crease the paper
          • canonbundy
            • Jun 2012
            • 607
            Re: Ir5065
            Check the small bearings on the ends of the Steel Roller located in the Duplex Feeder Unit, check also for flat areas on the Sponge Roller.
            Bearing XG9-0192-000
            Steel Roller -
            FB5-3322-020
            Sponge Roller -
            FB5-3321-000
            • Simons
              • Jun 2008
              • 490
              Re: Ir5065
              Yes, it sounds like its time for a fuser rebuild.
              • copicatt
                • Nov 2008
                • 366
                Re: Ir5065
                Hey guys, I wasn't notified of replies and hadn't checked the site. I agree that she can be mistaken. I will let you know.......Thanks
                • copicatt
                  • Nov 2008
                  • 366
                  Re: Ir5065
                  Well, she was correct. It only creases when doing 2 sided. pulled the LFR and the front bearing is shot and the LFR shaft is worn very thin. Have one on the way. Don't know why it only does it on 2 sided, but, oh well, used to want to figure out "why". Now I just repair and move on, lol.
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    Re: Ir5065
                    Nice find.
                    • Simons
                      • Jun 2008
                      • 490
                      Re: Ir5065
                      Yeah but when that happens make sure your UFR is in good shape or prepare for it to fail soon. I cant believe the UFR gear dint crack or bend the UFR with all that low roll press. Best to do it all when this happens.
