Canon IPF 8300S Hardware error
  • davidj7
    • 1107
    Hi
    i am having a problem with my Canon IPF 8300S printer . It all started with a replace printer head (left) message . I placed the call with the dealer and they sent a tech who interchanged the heads .After that I am getting a message " hardware error"
    So far I have replaced carriage assy pcb and both the printer heads .
    Even the dealer is stumped on this and he is just saying w'll try replacing Main controller pcb QM3-3203-0110. Ad even he is not sure if the problem will be solved .Any inputs on how to proceed on this one cause I dont want to spend a lot of money and pray I get lucky . Also FYI the tech tried to do a firmware update ver 1.07 that too failed.
    a machine is only as good as your tech : source:screwtape ; the scary one
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon IPF 8300S Hardware error
    I can not forget my case on this model.After replacing controller i turn on the printer without covers and accidentally drop the screwdriver on the new board and make disaster. Anyway......
    1. Start up the printer with the service mode and clear error.
    2.Replace the head relay PCB.
    3.Replace the carriage relay PCB.
    4.Replace the engine controller.
    5.Replace the system controller.
    Do not replace the system controller and engine controller at the same time.
    • V-P
      • Apr 2011
      • 679
      Would be too much to ask for the "hardware error" number ?
      • davidj7
        • 1107
        sorry this is the error: 03130031-2F26
        • V-P
          • Apr 2011
          • 679
          why did you replace carriage assy pcb ???
          Why did you replace both printheads ???
          Check carriage lubrication (movement) first.
          Can you turn it on to Online State ?
          When is the error happening - during first pass of printing ?
          Try to be more specific...
          • zoraldinho
            • Mar 2008
            • 5015
            This code have nothing to do with print head!
            03130031-2F26 Carriage motor error
            <Cause>
            The carriage did not operate because the carriage motor was overloaded due to a physical cause such as a jam.
            The carriage motor did not reach the specified speed within the specified time.
            <Probable fault location>
            Carriage pathway, carriage rail, carriage belt, linear scale, linear encoder, carriage motor, carriage relay PCB, or main controller PCB
            <Countermeasure>
            1) Carriage pathway check
            Remove foreign substances (jammed paper) from the carriage pathway if any.
            2) Carriage rail
            Visually check whether the carriage rail is dirty. If the carriage rail is dirty, clean it.
            3) Carriage belt
            Visually check whether the carriage belt is loose. If the carriage belt is loose, remove it and then reinstall it.
            4) Replace the linear scale.
            5) Replace the linear encoder.
            6) Replace the carriage motor.
            7) Replace the carriage relay PCB.
            8) Replace the main controller PCB.
            • davidj7
              • 1107
              Because the tech asked me to.
              It was asking me to replace print head (start of problem
              Yes its moving when tried physically.
              No
              Machine shows error when turned on
              • V-P
                • Apr 2011
                • 679
                When you turn the printer on - does the carriage make the standard movement left-right ?
                When you enter service mode - can you get to online state ?
                If you can enter sm - try to get some of the error codes stored in memory.
                Ask the customer about the problem. Did it just pop up or it was related to smth else.
                Generally 2F26 has no relation with Print Head status.
                Put your finger on the iron shaft (which holds the carriage) and slide it over. Do you see dirt or some kind of grease-ish ?
                • JustManuals
                  • Jan 2006
                  • 9838
                  You've helped me in the past, if you want the parts & service manual, send me an email to paul@justmanuals.com and remind me who you are. No charge of course.
                  Paul
                  • davidj7
                    • 1107
                    No It does not
                    I cannot enter service mode
                    Cant do
                    I explained in my first post It started with a print head replace message ." I placed the call with the dealer and they sent a tech who interchanged the heads .After that I am getting a message " hardware error""
                    No its clean .
                    • davidj7
                      • 1107
                      Paul
                      Paul its nice to know that you still remember me. At the moment I dont require anything cause I dont plan to intend to service this machine on my own . Its only when the tech's(Canon trained)goofed up that I am trying to fix this .
                      I have enough machines on my hand to take up most of my time.Thanks for the offer
                      • V-P
                        • Apr 2011
                        • 679
                        Why do I have the feeling that you are slightly irritated ???
                        Anyway: Go to the printer and do this:
                        While the printer off: remove the heads manually.
                        First ) turn the printer on in user mode = report back what happens
                        Second ) turn the printer on is service mode = report back what happens
                        After that put back the print heads.
                        • davidj7
                          • 1107
                          @ V-P
                          No i am not irritated at you , ofcourse i am mad at the at the guy who put me in this place .
                          I will do what you said that and get back to you . Its a holiday here so i will do that on Monday
                          • davidj7
                            • 1107
                            Update: I cleaned the ram and re inserted it Now i can get into service mode
                            Did This now the error on display is E196-404C
                            In service mode :
                            CPU:AADX0548
                            • V-P
                              • Apr 2011
                              • 679
                              It looks like you have 2 different serials.
                              Did you replace main controller PCB or MTC Relay PCB and DID NOT PERFORM the replacement routine?
                              if yes - than:
                              1) Turn off the power and disconnect the power plug.
                              2) Replace the main controller PCB.
                              3) Reconnect the power plug and turn on the power while pressing the [Paper Source] and [Information] keys. (Start the printer in PCB replacement mode.)
                              4) Release the key, but not before making sure that "Initializing" appears on the display. (The message lamp lights when printer enters PCB replacement mode.)
                              5) Wait until "REPLACE MODE" appears on the display.
                              6) Select CPU BOARD and press the [OK] key.
                              7) Turn off the power, but not before making sure that "Power off" appears on the display.
                              8) Turn on the power.
                              After you do this procedure - go back one post and report what I asked previously.
