IRC 4080/4580/5185 Fixing unit lifetime
  • Herrmann
    • Jan 2006
    • 792
    Re: IRC 4080/4580/5185 Fixing unit lifetime
    To give simple people some work,
    Trust me, this is not a job for simple people
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • Simons
      • Jun 2008
      • 490
      The unit has about 30 bearings. Indeed not a simple or fun job to do.
      • nogood boyo
        • Mar 2012
        • 156
        Well,
        Assisted in rebuilding the fixing unit... replaced the upper belt assembly. Managed to find a unit where the upper belt wasn't damaged.
        Now i guess it's just a matter of waiting to see how long this rebuilt fixing unit will last,
        thanks for all of the advice with this.
        • Fer
          • Nov 2009
          • 267
          #19
          Originally posted by nogood boyo
          Well,
          Did it complete FX-UHP-S and FX-LHP-S?
            • 16083
            #20
            GOOD PDF READ FOR NOVICE RE-BUILDERS
            Disassembling and Reassembling_Fixing Unit_TP07-168.pdf
            I never run that on personal re-built units/ learned my lessons just make sure u are in center position & flag is blocking correct sensor-
            I usually do a DCON clear/ then put back P PRINT settings
            always do a visible Inspect on New or Refurbish ones first
            & only use FX-UHP-S and FX-LHP-S on Canon Refurbish or New ones-
            • nogood boyo
              • Mar 2012
              • 156
              #21
              Aah well. Already done.
              Thanks for the PDF, great stuff... definitely going to come in handy.
              • nogood boyo
                • Mar 2012
                • 156
                #22
                Jesus.
                These Fixing Units are the worst, I just had another machine go down with a 007-0211 error code.
                This same code appeared on this same machine only four months ago... and i replaced the fixing unit with a brand new one. Now, 35 000 copies in, 007-0211. Again.
                Are there some underlying causes with these these fixing units failing after so few copies? or are they just kind of crap and really expensive?
                I've had five of these 007-0211 error codes (i only have five in the field) in under a year and its been gears in the same location. Apparently the only fix (according to the PDF's i have) is to order a new Unit.
                what a pain in the ass.
                  • 16083
                  #23
                  Jesus.
                  Crap doesn't deserve to be used here>SH.JPG is better
                  OLD CANON POST
                  E007-0211 during warmup
                  Check Sensor assy on the operator side at the exit delivery area, the one with the metal prong attached to check side to side movement. The prong that rides on the edge of the lower belt sometimes will slip under the belt and not be aligned correctly to sense the farthest movement.
                  • Herrmann
                    • Jan 2006
                    • 792
                    #24
                    You are absolutely right on this, a pain in the ass to work on, expensive and not lasting as long as they should do. We have 50 boxes of this kind in the field and i remember only one fusing unit which died a natural death. I have sent and still sending tons of fusing units back to canon to get a warranty refund.
                    • vigour
                      • Aug 2010
                      • 1038
                      #25
                      Jesus.
                      Is the firmware V65.17 or newer?????
                      • nogood boyo
                        • Mar 2012
                        • 156
                        #26
                        yikes.
                        good question.
                        The firmware version is on the p-print correct? DC-CON?
                        • charm5496
                          • 2387
                          #27
                          yes you can get your firmware information off of the p-print
                          latest version is 94.01.01
                          • nogood boyo
                            • Mar 2012
                            • 156
                            #28
                            So this metal prong was okay, but the bearing on the lower belt right above this sensor flag is shot.
                            can this bearing be replaced? i was going to pull it off of another busted unit.... but i'm skeptical about being able to put it back together.
                            • nogood boyo
                              • Mar 2012
                              • 156
                              #29
                              ahh. yes. firmware is good. thanks.
                              • nogood boyo
                                • Mar 2012
                                • 156
                                #30
