Canon C5045i - (very) slow copying and printing
  • nry
    • May 2025
    [Misc] Canon C5045i - (very) slow copying and printing
    Hi all, first post here for me! We have two year-old Canon C5045i copiers. One has recently started printing and copying extremely slowly, the other is still as it was when first installed. The slow one does speed up a little after a reboot cycle, but is still not as fast as the other - it is literally taking 8-10 minutes to make 30 copies of a one-sided A4 B&W page. Users have no access to settings, I am the only one who has admin access and I've never changed anything since install. Nothing shows up on Google so advice is welcome! Our support company is also a bit stuck at moment and our staff are getting understandably frustrated
  • canonbundy
    • Jun 2012
    • 607
    Re: Canon C5045i - (very) slow copying and printing
    You probably need to POST a bit more info to get a more informed reply from the Big Guns, like - Network, Fiery, Software Programs, when NOT connected to Network does the copy speed return etc. Otherwise install latest Firmware & try removing & reseating Memory Dimms.
    • nry
      You may have to ask for anything I don't mention! The copier is networked, printing and copying is affected and at present we have no network speed or performance issues elsewhere - it runs on a static IP on a fully GBit LAN. The printing is done from a Server 2008 R2 share on the latest drivers. The copier firmware has not been altered since install in Jan 2012. We don't use any fiery devices - I will try disconnecting from the network and see what happens
      • kuby
        • Oct 2007
        • 1373
        Sound like you need a new hard drive and a fresh install of the system software. Had a machine doing the same thing, that is how I finally resolved it. You could try taking the hard drive out of the other machine if they are the same and see if it resolves the problem.
        • nry
          Cheers, I will pass that back to the supporting company!
          • Rakesh
            • May 2012
            • 72
            check paper gsm, & re install printer drivers. also try printing on different PC.
            View Life As A Continuous Learning Experience...
            • nry
              It is happening for copying even if the network is disconnected if that makes any difference? Happens across all PC's too.
              • zoraldinho
                teacher-guide-expert-guru
                • Mar 2008
                • 4999
                Use Self Diagnostics tool to locate issue.If you get OK result try with initialize user settings.
                Controller self-diagnosis function.pdf
                • Fer
                  • Nov 2009
                  • 267
                  Is the interface slow and unresponsive? If so, replace the dimms of Main Controller 1 and reinstall software.
                  If only ouput is slow, there could be something wrong in the fixing film. Take to much time to heat up/cool off.
                  • Rachid.Akli
                    • Oct 2011
                    • 595
                    Hi to all,
                    I find the discussion and the different ideas very interesting.
                    If the HD is faulty, printing a single black and white page in several prints will not alter the speed. Once the document is sent to the RAM, the printing speed does not depend on the HD anymore. am i wrong ?
                    The printing speed may be affected by a bad positionning of the fixing belt during the print cycle. It always takes time to take the right position. Fixing belt part number: FM3-5951-000.
                    Good luck.
                    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
                    • Fer
                      • Nov 2009
                      • 267
                      Rachid,
                      The belt is a film, the only possition is wrapped around a single heater. It cannot really move or slide.If it doesn;t warm up right because of a broken heater, printing is slowed down.
                      Also if the main controller is slow, everything is slow.
                        • 16083
                        Copying is slow ?? / also what is your location ?
                        have u tried a line monitor test w/a print out reading ?
                        what test are u performing to substantiate this ?
                        and are your test the same speed for Printing & Copying ?
                        Glass copies =CPM
                        DF Copies = CPM
                        Full Color docs- CPM=
                        B & W Copies ?- CPM=
                          • 16083
                          Originally posted by Fer
                          Rachid,
                          do the easy stuff first-------------
                          Before replacing any boards or parts, remove the Dimms and Memory, clean and re-insert.
                          If fixing film is not maintaining the correct temperature it will cause the machine to slow down.
                          with no error or alarm codes
                          Don't u love those Canon Engineers
                          Check the service mode for TEMP-C in Display>Analog.
                          Check if the TEMP-C value is dropping to approx 150 degrees.
                          Normal value is closer to 190/200 degrees.
                          Replace the fixing film assembly: FM3-5950-000, and re-test.
                          OR
                          replace the hard drive
                          • Herrmann
                            • Jan 2006
                            • 792
                            Are the mashines at the same customer? if so, interchange them, and see if the error remains at the mashine or at the place, so you can sort out network errors on customers side. SEcond: does the slow mashine feed SEF per accident? if so, you are running into the problem all adv5xxx has, because there is no flux blend present due to the construction of the fusing unit. Feeding SEF or small formats results in a drastic slowdown of copy speed to prevent overheating in the non used fusing areas. No way around it, broken by design
                            If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                              • 16083
                              check the setting in service mode for FN-ENTMP.
                              This is found in level 1>Copier>Option>Im-Fix (second screen) and set from default '0' to '-3' and re-test.
                              from CANON USA--Printing and Copying Too Slowly
                              several cases this has been remedied by removing the fuser unit (four captive screws within the white plastic collars), then cleaning and re-seating the fuser connection.
