IR3220 Jamming
  • Brian8506
    • 1670
    IR3220 Jamming
    Jam codes 0101 and 0105. Lower tray only. If paper does get thru you can hear it crunching. Otherwise it may get up into the machine slightly and z fold. However if I apply a little pressure to the lower door it goes thru without any problems. Changed lower pfu. Door was changed 4 months ago. Looked for door updates similar to xx70 machines but found none. Anybody know of any? Wondering if maybe the upper pfu is at fault but upper tray runs flawlessly.
  • teckat
    • 16076
    Re: IR3220 Jamming
    Funny thing is if
    the registration flag (FB6-3399-000) on tray 1 paper pick-up assembly is worn down enough it will cause the jams. >from tray 2
    • Canon.Tech
      • Mar 2009
      • 335
      Re: IR3220 Jamming
      Yes as teckat said, but you can swap the two cassette feed units around as a test, they are the same (just swap the brackets) if it works fit a new unit or a new flag next visit.
      • Jamesu
        • Mar 2012
        • 101
        Re: IR3220 Jamming
        What i've done before is superglued a very tiny amount of plastic on to the end of the sensor, this sorted my problem without having to replace the whole thing... Of course it was just to get the customers machine working until i could get the proper part.
        Have you tried turning it off and on? No...Oh, it works now!
        • Brian8506
          • 1670
          Re: IR3220 Jamming
          Thanks all. Gonna try the upper pfu today. I thought about it after I left the cust yesterday. Will repost
          • bipc
            • Sep 2009
            • 193
            Re: IR3220 Jamming
            I usually just heat it up a little bit with a lighter and squeeze a little too the tip of the sensor and it stretches enough to work
            Life is a learning continuum...
            • charm5496
              • 2385
              Re: IR3220 Jamming
              plastic melting is an art form that I have learned through years that has saved my rear end a time or two.
              • bipc
                • Sep 2009
                • 193
                Re: IR3220 Jamming
                specially when you live far from canon warehouses and have to wait week and a half to two for a part (when available), or in older models with discontinued parts,
                life saver on NP series
                • Fer
                  • Nov 2009
                  • 267
                  Re: IR3220 Jamming
                  This my weapon of choice:
                  But i don;t see how this would help repairing the flag, i had those in stock, otherwise swap it with the no4 cassette.
                  • teckat
                    • 16076
                    Re: IR3220 Jamming
                    FL2-6580-000 is the updated flag from y2007
                    believe it had a metal backing
                    New Type
                    this particular flag is used in various models now
                    (inc.the cassette feed units)
                    for all u newbes & refurb people
                    imageRUNNER 2230, imageRUNNER 2270, imageRUNNER 2830, imageRUNNER 2870, imageRUNNER 3025, imageRUNNER 3030, imageRUNNER 3035, imageRUNNER 3045, imageRUNNER 3530, imageRUNNER 3570, imageRUNNER 4570, imageRUNNER C2620, imageRUNNER C2880, imageRUNNER C2880i, imageRUNNER C3100, imageRUNNER C3100N, imageRUNNER C3170i, imageRUNNER C3170U, imageRUNNER C3200, imageRUNNER C3220, imageRUNNER C3380, imageRUNNER C3380i, imageRUNNER C4080, imageRUNNER C4080i, imageRUNNER C4580,imageRUNNER C4580i, imageRUNNER C5180, imageRUNNER C5180i
                    • Brian8506
                      • 1670
                      Re: IR3220 Jamming
                      Pfu switch no good. Gonna try another lower door. Seems to be just 0101 codes now
                      • tech17z
                        • Feb 2011
                        • 7
                        Re: IR3220 Jamming
                        On the ir3220 the black plastic post that the door hook latches onto usually breaks off. This causes one side of the door to stick out just a tiny bit. Not enough pressure on the rollers. Since you stated that when you pushed on the door it worked, this is probably the cause. You can interchange the upper and lower pickup units. It should work fine after that, unless it's broken on that one too.
                        • Brian8506
                          • 1670
                          Re: IR3220 Jamming
                          Posts are fine
                          • Brian8506
                            • 1670
                            Re: IR3220 Jamming
                            PFU's and door replaced. Still jams. Apply a little pressure to the door and it works fine. So I grabbed the door on the sides, put my knee in the middle of the door and created my own pressure. So far it's working. Too bad there wasn't some kind of update like the xx70 series.
                            • teckat
                              • 16076
                              Re: IR3220 Jamming
                              so both the sensor flags had the updated metal cover
                              one thing to remember ---it's the upper (tray 1 )flag that determines the 01xx delay jams/
                              ?? did u replace the entire RIGHT DOOR ASSEMBLY(w/rollers/springs etc.)-FG6-9019-000
                              or just the Door PANEL -FB6-3503-000 ??
