Jam codes 0101 and 0105. Lower tray only. If paper does get thru you can hear it crunching. Otherwise it may get up into the machine slightly and z fold. However if I apply a little pressure to the lower door it goes thru without any problems. Changed lower pfu. Door was changed 4 months ago. Looked for door updates similar to xx70 machines but found none. Anybody know of any? Wondering if maybe the upper pfu is at fault but upper tray runs flawlessly.
IR3220 Jamming
Re: IR3220 Jamming
Jam codes 0101 and 0105. Lower tray only. If paper does get thru you can hear it crunching. Otherwise it may get up into the machine slightly and z fold. However if I apply a little pressure to the lower door it goes thru without any problems. Changed lower pfu. Door was changed 4 months ago. Looked for door updates similar to xx70 machines but found none. Anybody know of any? Wondering if maybe the upper pfu is at fault but upper tray runs flawlessly.is if
the registration flag (FB6-3399-000) on tray 1 paper pick-up assembly is worn down enough it will cause the jams. >from tray 2
flag.JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Re: IR3220 Jamming
Yes as teckat said, but you can swap the two cassette feed units around as a test, they are the same (just swap the brackets) if it works fit a new unit or a new flag next visit.Comment
Re: IR3220 Jamming
What i've done before is superglued a very tiny amount of plastic on to the end of the sensor, this sorted my problem without having to replace the whole thing... Of course it was just to get the customers machine working until i could get the proper part.Have you tried turning it off and on? No...Oh, it works now!Comment
Re: IR3220 Jamming
Life is a learning continuum...Comment
Re: IR3220 Jamming
FL2-6580-000 is the updated flag from y2007
believe it had a metal backing/
New Type
this particular flag is used in various models now(inc.the cassette feed units)
for all u newbes & refurb people
imageRUNNER 2230, imageRUNNER 2270, imageRUNNER 2830, imageRUNNER 2870, imageRUNNER 3025, imageRUNNER 3030, imageRUNNER 3035, imageRUNNER 3045, imageRUNNER 3530, imageRUNNER 3570, imageRUNNER 4570, imageRUNNER C2620, imageRUNNER C2880, imageRUNNER C2880i, imageRUNNER C3100, imageRUNNER C3100N, imageRUNNER C3170i, imageRUNNER C3170U, imageRUNNER C3200, imageRUNNER C3220, imageRUNNER C3380, imageRUNNER C3380i, imageRUNNER C4080, imageRUNNER C4080i, imageRUNNER C4580,imageRUNNER C4580i, imageRUNNER C5180, imageRUNNER C5180i**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Re: IR3220 Jamming
On the ir3220 the black plastic post that the door hook latches onto usually breaks off. This causes one side of the door to stick out just a tiny bit. Not enough pressure on the rollers. Since you stated that when you pushed on the door it worked, this is probably the cause. You can interchange the upper and lower pickup units. It should work fine after that, unless it's broken on that one too.Comment
Re: IR3220 Jamming
Posts are fineOn the ir3220 the black plastic post that the door hook latches onto usually breaks off. This causes one side of the door to stick out just a tiny bit. Not enough pressure on the rollers. Since you stated that when you pushed on the door it worked, this is probably the cause. You can interchange the upper and lower pickup units. It should work fine after that, unless it's broken on that one too.Comment
Re: IR3220 Jamming
PFU's and door replaced. Still jams. Apply a little pressure to the door and it works fine. So I grabbed the door on the sides, put my knee in the middle of the door and created my own pressure. So far it's working. Too bad there wasn't some kind of update like the xx70 series.Comment
Re: IR3220 Jamming
one thing to remember ---it's the upper (tray 1 )flag that determines the 01xx delay jams/
?? did u replace the entire RIGHT DOOR ASSEMBLY(w/rollers/springs etc.)-FG6-9019-000
or just the Door PANEL -FB6-3503-000 ??**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
