Canon IR 2620 - Feeder problems
  • aumir1
    Hi everybody
    Just brought one of these, the copier works fine and I was shown the feeder working. However when I got it setup the feeder worked the first day and never again. I've checked the cables and don't see any problems. Is there any other way to check what's happened. I get no green light from the feeder but if I unclip the cable the printer does recognise the feeders been disconnected. Any help would be appreciated.
  • Luther
    • May 2006
    • 682
    Re: Canon IR 2620 - Feeder problems
    you shouldnt get a green light until paper is present in the feeder, i would open the cover and check to see if the sensor arm is off or stuck.if the feeder doesnt detect paper it wont feed
    • aumir1
      Thanks, I'm pretty new to this photocopier, is there a picture or diagram somewhere that shows what the correct position for the arm should be or where exactly its located?
        • 16083
        Originally posted by aumir1
        Hi everybody
        see this link below
        http://www.copytechnet.com/forums/ca...-k1-issue.html
        • aumir1
          Originally posted by teckat
          Thanks for your help problem solved. It turned out to be the sensor on the feeder not berring pressed all the way down when the feeder was closed.
            • 16083
