Ir5570 wrong size original detection from platen glass
  • mrfuser
    • 1622
    Anyone know why a 5570 would detect legal when letter , not even letter r, is laid on the glass?
    thanks
    kelly
    • 16083
    Re: Ir5570 wrong size original detection from platen glass
    thanks
    kelly
    Check if the height of the feeder is incorrect causing the open/close sensors to not be activated.
    These sensors detect the open/close position of the cover. If the height is off and these sensors are not actuated properly, the size detection will be incorrect.
    also check--Level 2/ Copier/ Option/ Body SENS-CNF = set to "1" = 0: AB (default)
    1: inch
    Level 1> COPIER>OPTION>BODY>MODEL-SZ > set to "1" =inch (5R4E)
    next--------
    Level 2> COPIER>OPTION>BODY>MODELSZ2.
    This setting is used to enable / disable platen board original size detection ( for global support; AB / inch mix ) Check to see if this is set to "1".
    If this setting is a "1" it may cause the paper to be misread off the glass.
    last resort
    record or print your RCON Settings> then
    Perform an RCON clear (COPIER>FUNCTION>CLEAR>R-CON)
    power off/on re-enter RCON settings
