IR C3200 Error Code E000020-0460
  • SLAMISguy
    • 12
    I'm getting this code and can't find the SM online and would like to know what I am dealing with before I call the service company.
    THanks in advance,
    Jim
  • djzolla
    • 71
    hi there,
    The developer concentration
    target value is faulty (set when a
    new drum is fitted; the value is
    extremely small).
    The fault occurs when an image is being
    formed. It is detected when toner supply
    operation is started.
    04 = Black
    that is the manual description mate.
    gl
    • DadO
      • Dec 2007
      • 404
      If u haven't replaced developer's in a last 80k cmy,120k K or less(depend's) copies then u will get lot's of error report's related to developer's
      Cleaning didn't help....
      • SLAMISguy
        • 12
        I appreciate the info. Now I'm getting Error Code E000020-04b0. Any ideas?
        Thanks again.
        Jim
        • Copier_Guy
          • 543
          Thanks again.
          Jim
          Replace the Black Drum Unit.
          • Kopyrtek
            Copier Psychologist
            • Jan 2007
            • 407
            The drum is nearing the end of its life.Time to replace.Also need to clean the ATR sensor.
            • SLAMISguy
              • 12
              Thanks guys for the info. Is replacing the black drum as straight forward as it looks?
              • Kopyrtek
                Copier Psychologist
                • Jan 2007
                • 407
                Yea is as straight forward as you will find.Put the drum in and the machine will do a color calibration by itself...or auto gradation in Canon speak.
                • SLAMISguy
                  • 12
                  Black Drum Replaced - Image is off however
                  I replaced the black drum, piece of cake doing that. The problem I have now is that when I print, all of the colors appear to be offset. For example if I print a letter G, i get a black g, then a blue g a bit to the right of the black one, then a magenta g to the right of the blue and finally a yellow one to the right of the magenta. Hope my description makes sense. Many thanks again for your help.
                  Jim
                  • izone
                    • May 2008
                    • 5
                    remove the ITB unit. remove itb from unit wash it with soft soap water and all 4 colour sponge rollers also. dry it in sunlight. assembled all the parts. it really works. i alway use to do it for my irc3200
                    • izone
                      • May 2008
                      • 5
                      and also clean the salt sensor
                      • SLAMISguy
                        • 12
                        ITB Unit and Salt Sensor
                        Thanks for the info guys. Can you tell me where the ITB unit is and where the Salt sensor is? I don't have a service manual. Is there anywhere online to download a service manual?
                        Thanks again for all the info.
                        Jim
                        • izone
                          • May 2008
                          • 5
                          dear SLAMISguy
                          look at right side of m/c press the grey button remove the carraige and u will see the ITb(intermediate transfer belt) remove it. before removing it , release the itb by pulling the lever which is back side of front cover. salt sensor is located above the itb.
                          • Brianandkarin@ntlworld.co
                            Just replace the black drum unit (problem solved)
                            • kajsa39
                              • May 2008
                              • 28
                              Replacing the bk drum will correct this problem.
