IR 400 Constant paper jam
  • yormets
    • May 2009
    • 336
    Does anyone know what code I use to find the specific paper error in this machine. It has a constant paper feed error in the paper feed unit. I used to be able to clear it by unplugging the PF connector and then reconnect it. Isn't there a code that will tell me which sensor it is. I no longer have a manual other than Intrivia for this old box. Sometimes the machine clears itself. It hasn't for days now.
    • 23010
    Re: IR 400 Constant paper jam
    Jam code? Error code? =^..^=
    • teckat
      • 16083
      had an old list>
      but don't remember if this was for iR 400 or iR 600
      service mode
      (*)asterisk key>(#2,8 key)at the same time>(*)asterisk key
      COPIER>DISPLAY<JAM>
      01xx-Delay jam
      02xx-Stationary jam
      03xx-Residual jam at power-on
      04xx-Door open jam during copying
      05xx-ADF jam during stream reading
      xx01----Front deck (right) pickup
      sensor (PS20)
      xx02----Front deck (left) pickup
      sensor (PS25)
      xx03----Cassette 3 pickup sensor
      (PS37)
      xx04----Cassette 4 pickup sensor
      (PS42)
      xx05----Vertical path 1 sensor (PS47)
      xx06----Vertical path 2 sensor (PS49)
      xx07----Vertical path 3 sensor (PS41)
      xx08----Vertical path 4 sensor (PS46)
      xx09----Registration sensor (PS5)
      xx10----U-turn sensor (PS13)
      xx11----Pre-confluence sensor
      (PS14)
      xx12----Post-confluence sensor
      (PS15)
      xx13----Front deck (left) feed sensor
      (PS26)
      xx14----Front deck (right) feed
      sensor (PS27)
      xx15----Side paper deck feed sensor
      (PS106)
      xx16----Manual feed tray feed sensor
      (PS35)
      xx17----Side paper deck pickup
      sensor (PS101)
      xx0A----Fixing separation claw
      sensor (PS6)
      xx0B----Internal delivery sensor
      (PS9)
      xx0C----External delivery sensor
      (PS10)
      xx0D----Fixing/feeding outlet sensor
      (PS11)
      xx0E----Reversal sensor (PS16)
      xx0F----Duplexing reversal sensor
      (PS12)
      found another old doc------think from GP405 or iR400
      01xx Delay jam
      02xx Stationary jam
      03xx Timing jam
      04xx Protection jam
      10xx Residual jam at power-on
      11xx Door open jam during copying
      12xx Double feeding jam
      90xx Logic jam
      Last 2 Digits (sensor)
      xx01 Pre-registration sensor -------xx31 Internal delivery sensor
      xx02 Vertical path 1 sensor --------xx32 Bin 1 delivery sensor
      xx03 Vertical path 2 sensor --------xx33 Bin 2 delivery sensor
      xx04 Cassette 1 pick-up sensor ----xx34 Bin 3 delivery sensor
      xx05 Cassette 2 pick-up sensor ----xx35 Bin 3 inlet sensor
      xx06 Cassette 3 pick-up sensor ----xx36 Fixing assembly outlet sensor
      xx07 Cassette 4 pick-up sensor --xx37 Reversal delivery bin 1 delivery sensor
      xx08 Cassette 5 pick-up sensor --xx38 Reversal delivery bin 2 delivery sensor
      xx09 Cassette 6 pick-up sensor --xx39 Reversal delivery bin 3 delivery sensor
      xx0A Deck pick-up sensor --------xx3A Reversal delivery bin 3 inlet sensor
      xx0B Pre-registration sensor for --xx61 Duplexing assembly inlet sensor
      manual pick-up ------------------xx62 Re-pick up sensor
      • yormets
        • May 2009
        • 336
        Thank you. I'm assuming the Jam code is 010B. There were four jam codes all contained 010B.
        0228 2156 2156 0 010B 8 000088 Free is what the display read
        From your table is should be a delay jam of internal delivery sensor PS9. Which means the sensor never read it, correct? I wonder why it doesn't clear? I went back today and it's working again. Thanks for your help. Now I just need it's location. It must be a flaky sensor. Sounds like it's not even in the PF unit.
        • Brian8506
          • 1666
          Sounds like its looking for paper from bypass then jams. Theres a lever on the rear side of the right cover that pops out and the machine will think theres paper in the bypass and try to feed. Usually happens at power on. Most levers I've seen are black. Something to look at. 010B is bypass pre reg sensor
          • yormets
            • May 2009
            • 336
            Thank you for a plan of attack. If nothing else I'll change (swap) it with another. I'll check the sensor flag. This machine has only 51000 prints on it. It's a blue model. One of the last 400's I think.
