IR6055i Error E000001-0010
  • aabarnes1
    • Mar 2009
    • 620
    Good morning, I work mainly on HP, Kyocera and ricoh but have a customer with 2 6055i machines. 1 is showing the above error, could somebody advise me in the right directions please, as to what it is and how to clear it. Many thanks in advance.
    Grant me the serenity to accept the things I cannot change.
  • SAZ911
    • Mar 2013
    • 193
    Re: IR6055i Error E000001-0010
    FIXING ASSY HIGH TEMP ERROR (E-001-0010)
    should be as easy as clearing it and then restarting.
    To clear the error, go to service mode (*, 2 & 8, *) (the star with the circle around it...) > COPIER > FUNCTION > CLEAR, then select ERR and press OK.
    After you press OK, just power cycle the machine and you should be good to go.......
    SAZ911................
    SAZ911..........
    • aabarnes1
      • Mar 2009
      • 620
      [ATTACH=CONFIG]20057[/ATTACH]
      While I was waiting for a reply I reset the error in service mode, unsure as to wether it would clear, but it did. Thanks for your reply and letting me know the cause of the issue. The copier is up and running now and as it it is under warranty I'll get Canon out to have a look, thank you.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Consider getting some thermistors if the error comes back again.
          • 16083
          also monitor your wall voltages/
          make sure it has correct grounding reading -Ground>Neutral =0v>0.5v
          • THUK
            • 195
            Dirty Thermistor, fit new one.
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5007
              What happens with your repeat image on ira 4000?
              • THUK
                • 195
                Hi no cure at the moment, we are swapping it out and Canon want to look at it we will have to wait and see.
                i will update if they find a cure.
