Grey shade with Spots on copies IR2200
  • ldfrepairs
    • Oct 2012
    • 148
    Please find attach sample. Note the grey shade background with black spots. Replace drum unit. try adjustments in service mode; Dev bias adjustment but no improvement in quality
    drugstore-onlinecatalog.com
  • teckat
    • 16083
    Re: Grey shade with Spots on copies IR2200
    I see the copy scan issue
    is issue also on Prints ?
    • ldfrepairs
      • Oct 2012
      • 148
      Yes issue is also present when printing
      • teckat
        • 16083
        toner
        • ldfrepairs
          • Oct 2012
          • 148
          Geniune canon toner
          • teckat
            • 16083
            Geniune canon toner
            1-Composite power supply
            2-Differential PCB
            3-DC Controller
              • 23010
              Originally posted by teckat
              toner
              I'll say that it appears to be a developing issue of some sort. How many clicks on the developing unit? Could some aftermarket toner be mixed with the OEM? Without vacuuming out the unit it could take a very long time to rid yourself of the contamination through normal use. =^..^=
              • irtek
                • Jun 2009
                • 113
                Transfer Roller.
                • mido
                  • Nov 2011
                  • 177
                  clean the developing cylinder
