Problem copy from ADF canon ir3300
  • bua99
    [Misc] Problem copy from ADF canon ir3300
    Dear all,
    I have problem with my canon ir3300, if copy in plate glass it's good,
    But, when i copy from ADF, the margin different with original, it's different about 3 cm then original.
    Notes: i use paper 215x330 cm.
    Thx for your help.
  • northernlife
    • Sep 2011
    • 847
    Re: Problem copy from ADF canon ir3300
    lead edge? trail edge? inboard, outboard? Which direction?
    Originally posted by bua99
    Dear all,
    Thx for your help.
      • 16083
      Dear all,
      Thx for your help.
      U1: FOOLSCAP
      -- is your paper tray set for U1
      COPIER>OPTION>BODY>SCANSLCT
      - set to "0"When enabled, the scan size is determined in relation to the original
      size.
      Settings = 0: off (default), 1: on
      COPIER>OPTION>BODY>SENS-CNF-set to "0"
      Use it to set the arrangement of the original sensors.
      Settings = 0: AB-configuration (default, 1: Inch-configuration, 2: A-configuration)
      Caution- If you have changed the arrangement of the original sensors, select the appropriate
      setting to suit the new arrangement.
      COPIER>OPTION>USER>MF-LG-ST-set to "1"
      Use it to indicate the Extra Length key for paper up to 630 mm long
      (multifeeder, free; the ADF will also accommodate paper up to 630 mm
      long).
      Settings = 0: normal mode (default), 1: extra length mode (key indicated)
      • udayan
        • Aug 2018
        • 9
        Dear member,
        I have problem with my canon ir 3300 while coping from ADF, paper options are not coming in the feeder settings, how to obtain that. Can any one guide me.
        Udayan
          • 16083
          Originally posted by udayan
          Dear member,
          Udayan
          • udayan
            • Aug 2018
            • 9
            Sir, I can't see the options as you shown in the video. I like to know how to obtain the options. Like A4, A3, etc.
            My machine not showing the paper options, there. thanks,
            Udayan
              • 16083
              Udayan
              Sorry, wrong model on video ----disregard
              In service mode
              COPIER>OPTION>BODY
              MODEL-SZ
              Use it to select the mode of indication by destination and of the ADF original
              size detection.
              Settings
              0: AB (6R5E),
              1: INCH (5R4E),
              2: A (3R3E),
              3: AB/INCH (6R5E)
              Use it to enable or disable the original size detection mechanism for the
              ADF.
              • When enabled, the scan size is determined in relation to the original
              size.
              Settings
              0: off (default),
              1: on
              COPIER>OPTION>USER
              MF-LG-ST
              Use it to indicate the Extra Length key for paper up to 630 mm long (multifeeder, free; the ADF will also accommodate paper up to 630 mm
              long).
              Settings: 0: normal mode (default), 1: extra length mode (key indicated)
              is this how your control panel screen shows
              In service mode
              COPIER>OPTION>ACC
              DK-P
              Use it to select a paper size for use in the paper deck.
              Caution After making a selection, be sure to turn off and then on the main power
              switch.
              Settings 0: A4 (default), 1: B5, 2: LTR, 3: A-LTR
              Have you done this cassette adjustments ??????????
              • udayan
                • Aug 2018
                • 9
                sir, i will try this and see whether the options in feeder and feedsize coming or not. then i will reply to you thanks in advance.
                udayan
                  • 16083
                  udayan
                  what happened ?????????????
                  • udayan
                    • Aug 2018
                    • 9
                    [QUOTE=teckat;698400]
                    Nothing i can't have size in FEEDSIZE, as well as i can't see TRY-WIDE. can you help me, i think there is problem with some settings.
                    udayan
                      • 16083
                      [QUOTE=udayan;698498]
                      udayan
                      Sorry, wrong model on video ----disregard ----
                      did u check the other settings posted ???????????
                      is your issue just when using the ADF ??
                      do your paper trays read correct paper size ??
                      is size issue when paper is feed to glass from ADF ??
                      • udayan
                        • Aug 2018
                        • 9
                        In service mode
                        COPIER>OPTION>BODY
                        MODEL-SZ
                        size detection.
                        Settings
                        0: AB (6R5E),
                        1: INCH (5R4E),
                        2: A (3R3E),
                        3: AB/INCH (6R5E)
                        ADFSettings
                        0: off (default),
                        1: on
                        COPIER>OPTION>USER
                        MF-LG-ST
                        long).
                        [ATTACH=CONFIG]40527[/ATTACH]
                        In service mode
                        COPIER>OPTION>ACC
                        DK-P
                        switch.
                        [ATTACH=CONFIG]40523[/ATTACH]
                        [ATTACH=CONFIG]40524[/ATTACH]
                        [ATTACH=CONFIG]40525[/ATTACH]
                        [ATTACH=CONFIG]40526[/ATTACH]
                        Sir,
                        My Machine is not showing the paper size in ADF. So I cann't select the paper for ADF, It is coming A3 by Default. But I max. time needed in A4. How it show the automatically the paper size. Its urgent. Please help me, Udayan
                          • 16083
                          Sir,
                          https://youtu.be/UoHUEMJpwog
                            Sir,
                            My Machine is not showing the paper size in ADF. So I cannot select the paper for ADF, It is coming A3 by Default. But I max. time needed in A4. How it show the automatically the paper size. Its urgent. Please help me, Udayan
                            maybe CLEAN the size sensors in the ADF??
                            do you have user guide?
                            service manual?
                            are you a tech?
                            can you post pics of tray config from screen?
                            • udayan
                              • Aug 2018
                              • 9
                              service manual?
                              are you a tech?
                              Dear I am not a tech. in the ADF settings I will post the picture afterwords.
                              I can't get the page size in ADF settings as I seen in the videos, i think it is some software or other settings problem. If possible can you please help me.
                              Udayan
                              PS : where i get size sensors in the ADF, i have no idea, is the top panel where some plastic trangle parts are coming out to detect the paper.
