Canon C130/NP6512 Series problem
  • lasersmith
    • Mar 2011
    • 13
    [Misc] Canon C130/NP6512 Series problem
    Where does the spring that is behind the developing assembly attach? I have heard it referred to as a tension spring or pressure spring - it keeps the developing assembly snug up against the drum unit when the locking lever is in place. I downloaded the service manual, but the spring is not mentioned. It is hanging loose in the C130 I'm trying to repair - the top part was attached at one time, so I know where that end goes, but the bottom of the spring -? I tried attaching it one place by the gearbox to the left of where it's hanging, but that didn't work, and I can't figure out where it should attach. Any help would be appreciated.
  • teckat
    • 16083
    Re: Canon C130/NP6512 Series problem
    doesn't it attach to shutter arm
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      oh l have more experinance for this model cause insider my countries a lot of costumer use this model ...we have same this problems ....but cause we have better experiance we can solve any problems ..unfortunate if you can visited our workshop you can resulation your problems ...you are welcome there ...
      BEST TECHNICIAN . NICE PEOPLE .
        • 22997
        There used to be a black plastic post on the rear frame to attach the spring to:
        Light copies at the rear, and possible clicking noise. The developer shift rear return spring comes unhooked, when the post on the rear of the blanking assembly shears off. Remove the composite power supply, main drive motor, and backing plate. Drill a 3mm starter hole at the original post location and install a 4mm x 10mm plastic thread screw to hook the spring onto.
        • Brian8506
          • 1664
          This is perfect. It comes out stronger than the old post. I probably did 50 of these. Just eats a little time.
          • lasersmith
            • Mar 2011
            • 13
            Thank you for all the help! How do I visit your workshop?
            • lasersmith
              • Mar 2011
              • 13
              Thanks! I will have to drag this beast back to the shop and give this a try!
              • teckat
                • 16083
                Flight stats for Algeria - did you know-
                • There are 42 airports in Algeria and the 5 biggest are
                • Houari Boumediene Airport (Algiers, Algeria)
                  • Right now, 23 airlines operate out of Houari Boumediene Airport.
                  • Houari Boumediene Airport offers nonstop flights to 74 cities.
                  • Every week, at least 546 domestic flights and 630 international flights depart from Houari Boumediene Airport.
                  • Es Senia Airport (Oran, Algeria)
                    • Right now, 9 airlines operate out of Es Senia Airport.
                    • Es Senia Airport offers nonstop flights to 27 cities.
                    • Every week, at least 154 domestic flights and 154 international flights depart from Es Senia Airport.
                  • Ain El Bey Airport (Constantine, Algeria)
                    • Right now, 4 airlines operate out of Ain El Bey Airport.
                    • Ain El Bey Airport offers nonstop flights to 15 cities.
                    • Every week, at least 119 domestic flights and 70 international flights depart from Ain El Bey Airport.
                  • Oued Irara Airport
                    • Right now, 2 airlines operate out of Oued Irara Airport.
                    • Oued Irara Airport offers nonstop flights to 5 cities.
                    • Every week, at least 28 domestic flights and 7 international flights depart from Oued Irara Airport.
                  • Les Salines Airport (Annaba, Algeria)
                    • Right now, 3 airlines operate out of Les Salines Airport.
                    • Les Salines Airport offers nonstop flights to 5 cities.
                    • Every week, at least 63 domestic flights and 35 international flights depart from Les Salines Airport.
                • Canon.Tech
                  • Mar 2009
                  • 335
                  If he wants a hand I'll happily go to Vegas to fix it for him if he'll take me out on the town!!!!?????
                  • lasersmith
                    • Mar 2011
                    • 13
                    Alas, I could not show you the good time you are dreaming of....I really AM in Las Vegas, NEW MEXICO. Thanks anyway!
                      • 22997
                      I should have mentioned: Be very careful handling the composite power supply! There are various cut-outs and weak areas that can crack easily. Be very gentle and don't force anything. =^..^=
                      • Brian8506
                        • 1664
                        I was in Albequerque (did I spell that right?) in 2000 for a bowling tournament. Friends of mine from here in NJ looked on the map and saw Las Vegas was only 115 miles so they took the drive. Not the casino town they were looking for.
                        • Canon.Tech
                          • Mar 2009
                          • 335
                          So i'm not the only one!!!!! Viva Las Vegas!!! (New Mexico!!!)
