Canon Dadf-h1 separation issues
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    The doc feeder for the IR3300 series are quite a bit older now and I'm noticing at this age level , that they like to feed multiple sheets even after you replace the PU roller , Feed/Sep roller and the 2 sep pad assemblies. Any ideas as to what works for you to resolve this much appreciated-Blaze
  • teckat
    • 16083
    Re: Canon Dadf-h1 separation issues
    JAM CODES ?????????????
    Inspect & or > Replace the one-way pulley ( FB5-9466-000 )
    • blazebusiness
      • 1250
      No---no jam codes.....just a general question. I'll start replacing those one way pulleys then as part of the normal AF rebuild. Thanks for getting back to me.
        • 22934
        They're not much fun to get to. It's going to add time to your rebuilds. =^..^=
        • blazebusiness
          • 1250
          Yeah, but not much choice my friend. Now that those feeders are getting older it's going to be a required item. That machine sure is a great box. Still a lot of them out there even after all these years. After doing a couple of those one way pulleys my speed will greatly improve on installing that part. Thanks again for the responses. You guys are great.
          • Canon.Tech
            • Mar 2009
            • 335
            Yes I have seen the separation start to fail on this DF even with a new pad etc. I have replaced a few of these clutch springs but it doesn't seem to make any difference in the separation, after all that clutch only controls the pick-up & feed nothing to do with separation? Shame as this machine is very reliable, not even as good as the 2270/3225 etc
