IR 3570 scanning
  • copyman
    Owner / Technician
    • Sep 2005
    • 4648
    IR 3570 scanning
    "Canon Universal Send and Multi-PDL Print Package-A1"
    Will this work on a IR-3570 to get machine scanning? The customer is able to print at this time. Since this is new do I still need to call canon for code to activate or something else? Obviously Im not a Canon dealer so just want to make sure before I buy it. I'm confused because I see "B1" also listed as the scan kit for IR3570.
    Thanks in advance
  • teckat
    • 16083
    Re: IR 3570 scanning
    Thanks in advance
    there is a Package that includes both Printer Kit & Send Kit
    IR2270/2870/3570/4570, UNIVERSAL SEND & MULTI PDL PRINT PACKAGE A1
    remember _printer needs the "N" firmware installed
    The Multi-PDL Printer Kit-E1 /
    needs no license > comes with "N" Boot Rom & instructions for install + Scan Gear install
    outside USA u need to install the expansion RAM 256MB with this Kit
    Send
    function is available only if the optional Universal Send Kit is activated by registering a license key.
    A license key can be obtained via a Web Browser to access the license management system. Access the system by entering the following URL: Canon - MEAP -.
    For more information on obtaining the license key, see the License Access Number Certificate and the License Registration Booklet included with the various optional kits.
    The license key must be registered on the actual machine. You cannot register the license key through the Remote UI.
    • You do not need to register a license key to use the Fax function.
