in ir 2520 there is a major problem in the duplexing function if one command is given for 2-sided copy it works properly but if the command is given for more than one copy it do the first copy properly but in second copy it always pick up 2 papers with it which stops the copying and paper jam occurs, then i remove the paper and close the door then all the gears are continuously moving and no error code occurs
this is same with printout also
there is no error code
