ir 2520
  • pulkit jain
    • Dec 2012
    • 73
    ir 2520
    in ir 2520 there is a major problem in the duplexing function if one command is given for 2-sided copy it works properly but if the command is given for more than one copy it do the first copy properly but in second copy it always pick up 2 papers with it which stops the copying and paper jam occurs, then i remove the paper and close the door then all the gears are continuously moving and no error code occurs
    this is same with printout also
    there is no error code
  • grandmaster
    • Aug 2011
    • 9
    Re: ir 2520
    You can check this machine will work fine with A4 R papers.problem is with registration clutch which can be confirmed by swapping with multi pass clutch.
    • pulkit jain
      • Dec 2012
      • 73
      Re: ir 2520
      can registration clutch be repaired
      swapping with multi pass clutch (did you mean to change the registration clutch by multi pass clutch)
      please send a picture of registration clutch and multi pass clutch
      • pulkit jain
        • Dec 2012
        • 73
        Re: ir 2520
        (duplexing problem) ir 2520 please find attached picture and guide me where is the registration clutch and with which clutch it can be replaced
        please reply fast it is urgent!!!!!
          • 16083
          Re: ir 2520
          FK2-9154---all same Part #
          CL1 Registration Clutch
          CL2 Manual Feed Pickup Clutch--Cassette / Manual Feed Pickup Clutch
          CL3 Developing Cylinder Clutch
          CL4 Duplex Feed Clutch
          • pulkit jain
            • Dec 2012
            • 73
            Re: ir 2520
            is this the part number for all clutch FK2-9154---all same Part #
            if no then please send me the part numbers of all clutch
              • 16083
              Re: ir 2520
              all the same -did u read
              Attachment 21351
                • 23008
                Re: ir 2520
                Most Canon parts have the Canon part number or manufacturer number marked on the part somewhere. Just compare the numbers. No particular genius involved. Even I can do it. =^..^=
                • Canuck
                  Tech Specialist
                  • 1713
                  Re: ir 2520
                  Cheap plastic little clutches. Remove them,disassemble them and clean them with alcohol, re-assemble and re-install. Cleaned tons of the newer cheaper plastic clutches(5570 df,2020 cassette feed,3245 df...the list goes on)
                    • 16083
                    Re: ir 2520
                    ____:_
                    Used to cut those plastic spring wound clutches in NP2020
                    =better action\ long time ago;>}
                    • Canuck
                      Tech Specialist
                      • 1713
                      Re: ir 2520
                      Originally posted by teckat
                      ____:_
                      Yeah..the old days...Spring clutch with solenoid...clutches would get stiff inside and the arm would blow right by the pawl on the hub and feed extra sheets also along with slipping. NP3050 also......showing our age(lol). The newer plastic housing electro-mechanicals are junk. Old metal clutches(on np6050 for example) lasted for millions
