ImagePress C1 Error E000006-0002
  • victoryprinting
    • Sep 2012
    • 53
    [Error Code] ImagePress C1 Error E000006-0002
    I have searched for this error code, but have found no answer anywhere. It occurs when I start the machine up. Normally when I start up, I hear a clicking sound (part of the initialization routine, I assume). When I don't hear it, I get the red alert light with the error code. Sometimes, it takes several attempts to restart and then it works fine.
    • 23009
    Re: ImagePress C1 Error E000006-0002
    I can help a little. All the errors between E000000 and E000007 are fuser related. Changing the fuser and clearing the error should resolve the issue. If you cannot manage those two things, you'll need a service tech. =^..^=
    • Canuck
      Tech Specialist
      • 1713
      Fixing drawer connection error. Front door is closed but thinks fixing drawer is not closed.Check for paper dust,etc in the connector on drawer and machine...maybe even a piece of paper. Make sure connector springs back properly. This machine is built on a irc6800 chassis and they had problems with this. Actually modified connector assembly on 6800. Changed a couple myself(on the machine). Pain in the rear. Re-crimp the connector pins inside and clean contacts with alcohol. Gets coating of fuser oil on pins from vapors. Probably a mod kit for C1 also
      • victoryprinting
        • Sep 2012
        • 53
        Thanks much! For the moment, I just gently opened and closed the fixing drawer about a dozen times, which may have dislodged debris or fuser oil that was preventing a solid connection. It has started up fine ever since then.
        • Canuck
          Tech Specialist
          • 1713
          Good to hear
