Canon IC D1120 2nd request
  • mjarbar
    Guest replied
    Re: Canon IC D1120 2nd request
    Hello,
    I am going from the iR1133 series which in most cases is the same as your machine, the document end sensor is # WG8-5696-000 (PS702)
    I have marked the sensor with a red arrow, it can be removed by taking off the cover shown above. I would also make sure the rollers are free from any dust etc. and if required the part for the flag that activates the sensor is FC7-6321-000 which sits on the open/close cover of the doc feed.
    Hope it helps.
  • tcypy1961
    started a topic Canon IC D1120 2nd request
    I noticed that I mis-spelled a word and wonder if that is why I've not received a reply. The adf on this copier is pulling the original in and as it exits it stops. I'm thinking a dirty or faulty sensor; if this is the cause could somebody tell me where it is located and how to get to it and a part # please.
    Thanks!!!
