ir 2520 paper slip and fold in A4R
  • pulkit jain
    • Dec 2012
    • 73
    in ir 2520 paper got slip and fold in A4R mode from both drawer and stack bypass is this can happened because of duplexing clutch not working properly or because of FM3-9293-000 MULTI PAPER PICK-UP GEAR ASS'Y or because of FK2-1410-000 SOLENOID SL2 please go through the attachment.
    there is no error or jam code
    please reply fast it is very urgent!!!!!!!!!
  • canonbundy
    • Jun 2012
    • 607
    Re: ir 2520 paper slip and fold in A4R
    Looks like a hesitation entering the Fixing Unit, causing the fold to occur at the Registration Rollers
    Check for obstruction on Fuser Entry Guides and ensure the Fixing Film etc turns freely.
    • pulkit jain
      • Dec 2012
      • 73
      is the slip and fold in the paper can happen because of the fault by FU8-0576-000 GEAR, 18T/25T
        • 23010
        Just out of curiosity, Is the original being scanned through the document feeder a tri-folded document fed in the A4-R direction, like a mailed letter?
        It appears to me that the problem is occurring during the scanning process, because of a fold in the original. If that is indeed the case, and the problem does not occur with flat, not-folded originals, there isn't much you can do to prevent this.
        I would have thought that you would have adopted a less demanding way of asking, after your thread about not getting answers. =^..^=
        • pinkia
          • May 2009
          • 19
          Just swap your registration clutch with duplex unit clutch your problem will resolved as it is common problem in this model.
