ir7095 for printing
  • freefly
    • Jan 2013
    • 20
    ir7095 for printing
    Printer setting>Setting>print Quality>Density
    I can adjust the intensity level was 9.
    When the level is greater than 5 (6-9).
    Work out a sheet of paper (no ink stick).
    Please help.
  • HP:guy
    • Feb 2013
    • 279
    Re: ir7095 for printing
    You have fusing problem not a density problem. Is the fusing system heating? is the pressure adjusted right?
    • Canuck
      Tech Specialist
      • 1713
      Density should be at 5. As stated if its not fusing.......you got a fuser problem. If it was not heating up enough machine would error...guaranteed. Makes sure the bushings(plastic collars) on ufr have not self-destructed. They do. Once the flange separates from the rest of the collar, roller is riding on the bearing. Don't fuse too good under this condition...lol
      • freefly
        • Jan 2013
        • 20
        When I was new.
        I will have a photo.
        Thanks to everyone.
        • Herrmann
          • Jan 2006
          • 792
          In this case, you would get an E069 in addition, because the upper fusing roller gets HV from the transfer current which would be short out due to contackt with the bearings. More likely, the bearings of the lower fusing roller are worn or the pivot bolts of the lower fusing roller.
          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
          • Canuck
            Tech Specialist
            • 1713
            Been there many times...especially when another tech installs front collar backwards and bearing rides on fuser frame...that pile of metal shavings on the fuser entrance guide usually is a hint...lol
