transfer belt c3220 or something else cleaning blade
Re: transfer belt c3220 or something else cleaning blade
Originally posted by pc123321
any advice are welcome
thanks
remove all drums>toners>fuser unit(keep duplex part slid out) remove ITB> remove cleaning blade assbly> take a flashlight look inside toward cleaning unit rail> get a vacuum (unplug printer first) and vacuum out all that waste toner on rail> & wipe down the Mylar sheet
Keep the ITB UNIT out
remove the metal plates> see undersides> bet they are dirty throw the large plate in the garbage
now put back the small plate<> make sure to screw(1) in varistor(2) > then attach other varistor end under leaf spring ( see pic)
varistor need to be grounded under leaf spring (no where to screw in) or u will receive a random error code
Hi,
how many copies has that magenta drum done, by the looks of the copies posted that drum is way past its life........time for a clean and service then replace the drum.
Originally posted by SAZ911
Hi,
yellow : 50
magenta : 56
cyan : 50
black: 57
what wrong with me
Originally posted by Canon.Tech
The picture of the magenta drum you posted is not from the C3220!?
one reason is very clear ----
all,this drum is not made by me ---that is for sure
i did not know where it made from ---
from ebay ------i did not want to mention more
i bought cyan and yellow from internet ,they got drums from tonermax---
before that cyan and yellow bought from ebay , when i open there is no tearing strip , that means two drums are used and sealed again to auction
the magenta drum is also bought from ebay ,it looks like new , all new packing , all my drums came from ebay (hp drum hp 8560...)before , this one is oem drum but it didn't like oem ----it's compatible or premium ,,,sounds strange
i bought one black from new york loyal computer ---canon dealer the sales respresentative said you drive 75miles round trip to got black drum
