Canon IC-6590 no power
  • copyman
    Owner / Technician
    • Sep 2005
    • 4724
    Going out to look at this machine. Customer said the power light is lit but will not turn on. Is there a fuse or any known problem with pwr supply boards going bad? Or any other suggestions? Only 6k on meter.
  • canonbundy
    • Jun 2012
    • 607
    Re: Canon IC-6590 no power
    Not sure if the model is a typo error - however turn mc off/on and check for possible Fixing Error in Srv mode - clear error then off/on.
    • Brian8506
      • 1665
      Also check for "download standby" message. Display lights may not be on but the message would still be visible.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4724
        Thanks for the replies. It is definitely a IC6590.
        Brian, If that "download standby" message is on display what does that mean?
        Thanks again
        • Brian8506
          • 1665
          Firmware problem. You may be able to clear it by holding down 1 and 9 while turning power
          Thanks again
