IR 2270 jamming at A4 in PS3
  • mido
    • Nov 2011
    • 177
    [CQ] IR 2270 jamming at A4 in PS3
    The problem is jamming in A4 size in PS3 sensor when copying in double side mode only. No problem in single side.
    The copy wrinkled as shown in the picture.
    I changed the heater unit but stay jamming in the same position. Also change the setting of the fixing also same same . Please any idea about this problem.
    Regards
  • Dan Dryer
    • Jan 2008
    • 57
    Re: IR 2270 jamming at A4 in PS3
    What's the jam code?
    Based on your pictures, I'd check the movement of the 2nd Delivery Flapper. Make sure it isn't sticking to the dampers behind it.
    • mido
      • Nov 2011
      • 177
      No, I am sure not sticking to the dampers, if it is sticking the single copy will jam.
      Only when copy double side jam.
      The jam code is 207 , PS13
      • canonbundy
        • Jun 2012
        • 607
        Check & clean inside 3 Way Unit.
        Replace PS13.
        Replace Fixing Film Assy with a NEW one.
        • mido
          • Nov 2011
          • 177
          Replace PS13.
          I replaced the fixing unit with another one but stay same same.
          I will try to replace the PS13
          thanks
          • Dan Dryer
            • Jan 2008
            • 57
            If the 2nd Delivery Flapper sticks down or doesn't lift quickly enough it will only affect double-sided. The paper doesn't travel under there for single-sided.
            If there was a problem with PS13 it would affect single-sided, so I doubt that's the cause of your jams.
            • Blizzoo
              • Aug 2013
              • 608
              Hi,
              As in the previous posts,i think the 2nd Delivery Flapper stiks on dumpers...try to remove the dumpers and make some tests ,it will be a little nois when solenoid actionate.
              it's a common problem with this copier model
              • doktor
                • 214
                Try: add an extra wrap to sensor PS13, which is the fixing outlet sensor.
                • Canuck
                  Tech Specialist
                  • 1713
                  As stated remove the dampers. If getting on duplexing,make sure to remove ALL 4 DAMPERS on the upper delivery diverter
