IR3035 ADF Scanning for Duplex when not selected
  • NetTech10305
    • Jul 2025
    Hey guys, thanks for reading. I have a Canon IR3035 that when scanning through the ADF will scan as if it's going to do double sided prints even though it is not selected. It doesn't actually print the both sides it just scans. When I select duplex it does just one extra pass through the ADF and will print double sided. It takes a lot longer to copy multiple documents through the ADF because of this. Any and all help is greatly appreciated. Thanks!
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Re: IR3035 ADF Scanning for Duplex when not selected
    Did you try initializing your copy settings in additional functions.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Are you a tech?
      For the hell of check these settings in service mode.
      Check the setting under COPIER>OPTION>BODY>LEVEL 2>SCANSLCT. (*28* *2 COPIER>OPTION>BODY>SCANSLCT.) There are two settings available.
      0: OFF (Determining the scan area by document detection)
      1: ON (Determining scan area by paper size)
      If the setting is "1" the feeder will scan the original twice. Set to "0" for single scanning.
      • NetTech10305
        Yes im a tech. Not as knowledgeable as I would like to be but I try. I have a initialized all copy settings and it still did it. I will check those settings in service mode when I go back. Hopefully that's it but I don't know how it could have been changed. Thank you for your reply. Any other tips would be helpful so I can be prepared when I go back. Thanks
        • SCREWTAPE
          East Coast Imaging
          • 3396
          If I find anymore info on it I will pass it on.
          • Brian8506
            • 1664
            This procedure will fix it. I've had it before.
            Originally posted by SCREWTAPE
            Are you a tech?
            • NetTech10305
              Thanks for your help screwtape. That was the issue exactly
