"Load Paper" When trying to print #10 envelopes from MS Word on C2230
  • c2230
    • Oct 2013
    • 40
    Hi all.
    I'm stumped. I am trying to print a #10 envelope from word using the MP tray. I put the envelope in vertically face down (without the envelope feeder) as stated in the manual, select the paper type and size accordingly into the imagerunner and it keeps telling me to load the paper that's already loaded! If I do to register a custom size, the minimum height it allows is 5.25" or something so I can't put it in the orientation specified. Any advice? Thank you.
  • c2230
    • Oct 2013
    • 40
    Re: "Load Paper" When trying to print #10 envelopes from MS Word on C2230
    ^bump^
    • ZOOTECH
      Senior member of CRS
      • 3375
      Originally posted by c2230
      Hi all.
      Try changing paper type/size, then load envelopes in tray.
      • northernlife
        • Sep 2011
        • 847
        What software are you printing from? UFR/PCL/PS and version? If you just send a test print job via the bypass does that feed fine if you just use regular LTR paper?
        • c2230
          • Oct 2013
          • 40
          Yes. Odd thing is that it doesn't feed from the specified orientation. The long side (Y) should be parallel to the feeder and the short side (x) should be perpendicular. I can print it horizontally but it's not correct because the machine doesn't have the optional inner finisher. If I go to set a custom size, the minimum (x) length you can enter is 5.50" which doesn't make any sense because the com10 (x) is 4.125" so the machine doesn't accept it's own orientation specifications using the MP tray. Why then does it say to place the com10 envelope vertically into the feeder when the minimum vertical (x) size it accepts is greater than the specified envelope size? It only works horizontally if I set a "custom" com10 size instead of as indicated on the screen and MP tray guide.
          WTF is going on here! Can I manually swap the X and Y minimums? Right now the machine reads as if it won't take anything less than a 5.50" vertical feed in the MP Tray. It has its orientations confused. How can this be fixed? Service Mode?
          • northernlife
            • Sep 2011
            • 847
            load_paper.pdf
            Check this tip and let me know.
            and check Settings / Registration > Function > Common Settings > Paper Feed > Paper Auto Selection > Printer > Bypass to 'ON'.
            • Canuck
              Tech Specialist
              • 1713
              The application is over-riding the driver. In Word under page options(i believe),check the settings for the envelope.Correct envelope has to be registered in Word. Even if you pick COM10 in the driver(having registered envelope as COM10 in the manual feed tray),it has to be told back in Word to use COM10. Sounds confusing but I've been down this route a few times. The flaky photo-interrupt(changed many) has to do with detecting any paper inserted in bypass tray. If you have no issues sensing other media put into manual tray(stick it in,asks what size),then it is not the machine but the way the job is sent to it. Bet a beer Word is causing it or VR for bypass has to be re-programmed(service mode)
              • c2230
                • Oct 2013
                • 40
                Originally posted by northernlife
                [ATTACH]22408[/ATTACH]
                Thanks for the reply. I already made sure this setting is set to off. Very strange. The printer specifies the COM10 size but acts as if there's not COM10 envelope in the paper tray. Again, I can't even set the COM10 to a custom size as both the X and Y measurements are under the minimum allowed size. This is a very very very bizarre glitch.
                • c2230
                  • Oct 2013
                  • 40
                  Already done. I've used this driver with the LBP7780Cdn and MF9280 without any problems. The printer does not accept the suggested orientation. You can't even specify a custom vertical (X) size that is under 5.50".
                  • northernlife
                    • Sep 2011
                    • 847
                    Can you do a straight copy from the BP with it set to com10? Just be thankful you don't gotta muck with Wordperfect
                    • teckat
                      • 16083
                      Hi all.
                      Message to "Load Paper" when Printing to Envelopes
                      Check if the Feed Method is set to "Print Side Priority"
                      if so > change to "Speed Priority" should resolved the issue.
                      Press (Settings/Registration) → [Function Settings] → [Common] → [Paper Feed Settings] → [Feed Method Switch] → "Speed Priority"
                      *Note*
                      Print Side Priority prints on the side facing up- envelopes are required to be face-down in the bypass.
                      or--User is Prompted to Load Paper when Printing on Envelopes from Microsoft Word
                      The problem can be resolved by setting the proper Feed From location in the Printing Options section of the Envelopes and Labels Window in Word.
                      The proper Feed From location is AUTO.
                      To set this correctly:
                      1) On the Tools Menu, select Envelopes and Labels.
                      2) Within the Envelopes and Labels Window, select the Options button.
                      3) This will bring up a new Window with two tabs: Envelope Options and Printing Options. Select the Printing Options Tab as shown below.
                      4) At the bottom of this Window, you will see the Feed From drop down Menu.
                      5) Set this option to AUTO or the Envelope Tray and this should resolve the problem.
                      • c2230
                        • Oct 2013
                        • 40
                        *Note*
                        • c2230
                          • Oct 2013
                          • 40
                          Anyone other ideas?
                          • northernlife
                            • Sep 2011
                            • 847
                            What version of driver are you using?
                            If you put a LTR sized sheet in there does it recognize and copy it bang on? In other terms, does the bypass function as it should completely ignoring the envelope issue?
                            • c2230
                              • Oct 2013
                              • 40
                              No. Whenever I put paper in the MP tray the machine asks to manually set the paper size and type from the display. Is that wrong?
