Horizontal lines on copies.
  • aakash@24
    • May 2011
    • 41
    [CQ] Horizontal lines on copies.
    I am facing this problem in ir 2830 .Horizontal dark black lines on copies .I have replaced drum 4 times and the same problem arises after 3-6k copies. I have changed the DP unit ,drum unit ,transfer section.I dont understand the problem,can it be HVT.
  • Canon.Tech
    • Mar 2009
    • 335
    Re: Horizontal lines on copies.
    This is a firmware issue, it causes the primary charge to stay on & burns those lines into the drum!you need to update the machine firmware to the latest version that has that bug fix & unfortunately fit a new drum!
    • aakash@24
      • May 2011
      • 41
      does that mean i have to upgrade the HDD to a newer software or i have to change the IP board
      • northernlife
        • Sep 2011
        • 847
        just flash the software with SST and you'll be good to go. As always, just in case, perform a p-print first and maybe even a backup of user settings just in case something goes wonky.
        • aakash@24
          • May 2011
          • 41
          will try the same tomorrow.lets see what happens.frustrated with the problem for over a month now?
          • aakash@24
            • May 2011
            • 41
            today replaced the HVT and the machine is working fine.But dont now for how much time.
            • Canon.Tech
              • Mar 2009
              • 335
              The fault will return & will damage another drum UNLESS YOU UPDATE THE FIRMWARE!
              • aakash@24
                • May 2011
                • 41
                Originally posted by canon.tech
                the fault will return & will damage another drum unless you update the firmware!
                do i have to upload all the files through sst
                • aakash@24
                  • May 2011
                  • 41
                  will it help if i replace the hdd with a new software pre insatlled
                  • Canon.Tech
                    • Mar 2009
                    • 335
                    If you have a HDD with the firmware preinstalled use, that easy to fit, especially if you dont have the firmware or SST!
                    • aakash@24
                      • May 2011
                      • 41
                      thx for help. i have a hdd of 2830 with firmware software pre-installed .
