Downloading Firmware
  • Jekjek
    Hi,
    I have Problem when downloading firmware IR5570
    The machine already connected to the pc.
    when i try to hdd format,
    i got notice "HDformat, if it is required, register it to the SST"
    and then i try downloading firmware,
    i got E244.
    what should i do??
    how to register HDD format to the SST??
    regards
  • HELIO240
    • Jan 2011
    • 137
    Re: Downloading Firmware
    Hi, Your service support tools seem be a old version 3.11 this version is not compatible with the equipment the last version is 4.72 . Try a last version.
    • canonbundy
      • Jun 2012
      • 607
      As HELIO stated - download the latest version 4.72 of SST, here is an explanation of your SST Error (though it is an IR7000).
      Service Support Tool Error E244
      Error response 0803: Write error has happened on the machine.
      This error will occur when a HDD Format is not performed prior to upgrade.
      The ALL_HDF Batch File and Formatting the Hard Drive
      The ALL_HDF batch file does NOT format the HDD. The HDD must be formatted by using the HDFormat file. On the iR7000 machines, you must connect to the device in 'Single Mode' to format the HDD with the HDFormat file.
      • Canon.Tech
        • Mar 2009
        • 335
        Yes install the latest SST & if that doesn't work delete & reinstall the firmware to the SST.
        I have the new SST on my website below (free download)
        • jrryval
          • Jun 2015
          • 5
          Hi. Where? May you help me? I don't see the link or the URL to your website
          • teckat
            • 16083
            • copier tech
              • 8164
              Caring is sharing!
              Here's the SST you need:
              MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
              โ€‹
              • jrryval
                • Jun 2015
                • 5
                Caring is sharing!
                https://mega.co.nz/#!FY0Q1CDK!4vDmL4...vgKyhLc4zA3AI8
                Thanks a lot!!!!
                • jrryval
                  • Jun 2015
                  • 5
                  Caring is sharing!
                  My misstake... I need for imageRunner 3300with network conectivity.
                  Thanks in advance
                  • teckat
                    • 16083
                    Thanks in advance
                    U show SST & 5570 in your post
                    there is no individual SST for iR's all use the same SST--
                    • copier tech
                      • 8164
                      Does the post mean he needs the firmware AND the SST!?
                      Here is the IR3300 firmware, it has both the copier & network version, make sure you select the correct version when uploading to the copier, if not you will get a mismatch error.
                      โ€‹
                      • jrryval
                        • Jun 2015
                        • 5
                        https://mega.co.nz/#!BM8k1T5R!b-vxqu...FvBRqz3IxfxD9w
                        Thank you very much!!!!
                        • jrryval
                          • Jun 2015
                          • 5
