I am facing this problem in ir 2870.The print on A3 copies rear side washes off.Changed fuser but the problem still persists.
print not fusing during A3 printing
Re: print not fusing during A3 printing
Try increasing the temp COPIER>OPTION>BODY>TEMP set to 7 (default is 0) -
Definately the Fixing Unit, check for uneven pressure of the Pressure Roller Bushings - replace the Fixing Film Assy.Comment
i recommend you replace both the fixing assy and the pressure roller if there is an issue with the fixing assy.
good luck....SAZ911..........Comment
