IR3320n blows 10A fuse, error E000803-0000
  • mjunkaged
    • 383
    Hey guys:
    I went out to look at a Canon IR3320n copier that had gone through a blown power company transformer power failure/restoration.
    Inspecting all fuses after attempting to clear the errors in service mode, found the 10A fuse on the INNER power supply unit (not sure the name) was blown and black.
    Installed another 10a fuse and it blows immediately on power up, same error. I ohm'ed out the fuser leads (removed it) and got about .5megohm on one, 1 megohm on the other, heater leads ohm out at 24 ohms each white to common black.
    Is it the power supply, and can someone feed me the name of it and part number? Or are there more things I need to check first??
    Thanks in advance for any help. If anyone knows where I can get an inexpensive parts and service manual that would help as well.
  • teckat
    • 16083
    Re: IR3320n blows 10A fuse, error E000803-0000
    Switching Regulator = FH3-2613-020
    • Canuck
      Tech Specialist
      • 1713
      Canon had a problem with these power supplies. Make sure you get one of the modified ones(modified by Hytec)..usually machine tosses out e001,e004,etc. Changed a few of them years ago.
