Canon C3220 Offset image
  • repairman
    • Oct 2013
    • 13
    C3220 with offset image in black or color modes.
    if you open and close the fuser section it resets to normal for a day or so then gradually gets worse.
    I have not been out to this copier yet due to distance and another company asking us to help. So before we drive 50 miles thought I would see if anyone has seen something that may cause offset imaging. Worked on many over the years and have not had one with this symptom.
    They are telling me they have replaced:
    ITB
    All drum units
  • HP:guy
    • Feb 2013
    • 279
    Re: Canon C3220 Offset image
    Print out a P-print then run a Dcon clear and reset all the settings on the print list.
    • repairman
      • Oct 2013
      • 13
      Sounds good. will do.
      we may pack a parts machine in the van to this call. Have you seen any drive related failures causing offset?
      • HP:guy
        • Feb 2013
        • 279
        No if you run and auto gradation you will see the colors don't line up properly.
        After the dcon clear they should line up.
        How bad is the offset?
        • repairman
          • Oct 2013
          • 13
          He said it looked about 2 or 3 mm
          • teckat
            • 16083
            DO NOT do a DCON Clear > until u Print out the P PRINT SETTINGS > u will need to reload DCON settings
            check if offset in MAIN SCAN or SUB-SCAN or both
            read this pdf
            TP03-1.pdf
            • repairman
              • Oct 2013
              • 13
              Thanks Tekat that was more than helpful.
              I will report back on this. The fact they can open then close the fuser section and it works for a while has me leaning to the itb drive and the dcon reset cant hurt for sure.
              • teckat
                • 16083
                opening & closing fuser is only doing a re-set of Patch Image Alignment on ITB sheet
                temp fix> this opening & closing (constant pulling out / pushing in of fuser can damage connection
                • Simons
                  • Jun 2008
                  • 490
                  Check the door specs and check that the patch sensor is clean and set to the door specs. If someone cleared out the system . They may not have got that value put back in ?
                  • repairman
                    • Oct 2013
                    • 13
                    sample images atached
                    dcon clear and reset factory values
                    full gradation adjust
                    Black copy mode and prints are good
                    color mode and ps test print shows offset
                    I will be going back out in a couple days. It has a c2 imagepass and its password protected. should be able to get in when i return
                    • teckat
                      • 16083
                      pull out the LASERS and do a Manual adjustment to set their home position
                      adjustment is at end of tech pub below
                      READ
                      TP03-1.pdf
                      make sure to do your FULL AUTO GRADATION for Printer/
                      then do the calibration for imagePass C2
                      do u have the Kodak Gray Scale or a Densitometer
                      Calibrate the Fiery RIP.
                      Enter calibration mode on copier through Printer, Settings, Functions, calibration, enter Fiery.1 for the password and press OK.
                      If you do not have a densitometer choose the Standard Color Cal Measurement page method under set-up. Use a clean Gray Scale positioned in the top center of the letter size portrait area of the platen glass.
                      Press Calibrate and Yes to print the Measurement Page.
                      Place printed page over the Gray Scale and press Yes and then done to measure.
                      After successful measurement press Yes to overwrite and to it affecting all users.
                      -Print out a Test Page and Configuration Page. Under Printer, Print Pages, Test Page the Configuration. After verifying print quality place these with the COMPLETED Service Log attached to the machine.
                      • Canon.Tech
                        • Mar 2009
                        • 335
                        This is such a common fault on this model. The transfer belt slips caused by leaking toner (usually from the black drum) all you’ll need to remove the transfer belt & clean the INSIDE of it & also clean the large rubber drive roller, make sure you clean both these items well., then do a DC CON CLEAR ONLY.
                        The machine will correct it’s self after either a full auto gradation or a long colour copy run, or as you are doing open & closing the left fuser draw.
                        • repairman
                          • Oct 2013
                          • 13
                          Thanks Teckat. I should have the greyscale. Get back on this
                          Canontech: The ITB has been replaced and dcon / gradation done as mentioned earlier but thanks
                          • Simons
                            • Jun 2008
                            • 490
                            I hope all your ITB bearings are good.
                            • teckat
                              • 16083
                              that Large metal ITB cover causes a lot of CQ issues> especially streaks
                              I take them off & throw them in the Garbage----have thrown away hundreds
                              leave small one on
                              but u need to connect other side of the varistor from small metal cover under leaf spring (because no screw hole available) ( not doing this will cause an error)
