screen information gone screen go blank
  • pc123321
    • Dec 2012
    • 103
    c3220 machine start up and warm up complete
    a while screen go blank no information on the screen
    why?
  • Brian8506
    • 1665
    Re: screen information gone screen go blank
    Is it just in sleep mode? Check sleep time under timer settings
    • teckat
      • 16083
      why?
      is the POWER GREEN indicator ON
      other than posted Sleep check/
      First I would remove > clean ends & Re-seat the memory DIMMs
      Check the Main Controller PCB LED101 which is ON during normal operation. When you experience a blank LCD screen, inspect the Main Controller PCB LED101, if the LED is OFF, then replace the SRAM PCB (FG3-3669-000) which is mounted on the Sub Main Controller PCB.
      Check the connection between the Sub-Main Controller (J1303) and the Main Controller (J1209) to see if they are seated correctly.
      Ensure that the voltage between the neutral and ground poles is 1/2 a volt or less.
      Could also be a Power Distribution PCB issue
