Canon ir5065
  • Hong1007
    • Nov 2013
    • 41
    [Dead] Canon ir5065
    I have a problem with the machine ir5065.
    went i use the feeder copy 2sided document come out a blackline, use the glass is no.i oso services the feeder inside
    mirror oledi,what is the problem please help me.
    thank you ..
  • Brian8506
    • 1664
    Re: Canon ir5065
    Check the scanner glass on copier and the 2 sided scan glass behind the DF copyboard cover. May be that something is blocking the scan path
    • Rachid.Akli
      • Oct 2011
      • 595
      Re: Canon ir5065
      thank you ..
      Hello,
      Although i have not well understood the end of your message, i would suggest that you clean and verify the document feeder reading glass.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
