CANON iRC3580 Copies Fine Print Very light
  • apollo
    • Mar 2008
    • 191
    [CQ] CANON iRC3580 Copies Fine Print Very light
    Hi Everyone
    Copies b/w and colour fine from copy glass, but when you print from any PC copies are very light
    on colour and B/W.
    Also when you do config page on additional function for printer also same light, but
    Isend and network report print fine.
    Tried PCL6 PCL5c and UFRII drivers no joy
    Updated to latest Firmware as well
    checked all drums itb earthing plate on door etc no joy
    Any input would be appreciated
    thanks in advance
    • 16083
    Re: CANON iRC3580 Copies Fine Print Very light
    Originally posted by apollo
    Hi Everyone
    on colour and B/W.
    thanks in advance
    If Internal Prints (Test Prints,Config Pages) are Light including Network Prints ( using a Imagepass-J1 or from PCL Printer Kit-Q3 ) u need to remove those calibrations-
    Then do a FULL AUTO CALIBRATION (Auto Gradation Adjustment -Select Printer Only >> THEN USE YOUR EFI Spectrometer/or X-Rite Densitometor or KODAK GRAY SCALE TO RE-CALIBRATE (Fiery RIP Calibration)
    • apollo
      • Mar 2008
      • 191
      Hi
      does not have fiery just standalone print.
      I done full calibration, auto gradation adjustment and the calibration prints are good but still same issues
        • 16083
        Hi
        Multi PDL Print Board could be bad or needs ends cleaned & re-seated >>>
        set Toner Saver Mode to OFF--
        Print out a PS Configuration Page to verify. Under the Print Quality section, make sure the Toner Save option is set to OFF.
        If it is set to ON, Press Additional Functions, Printer Settings, Settings, Print Quality and then Toner Save to OFF.
        if applies>>>>>>>
        Go to the UFR printer driver: Properties> Quality> Print Details> Toner Save and select "Off".
        toner save mode is set to "On" by default on the UFR printer driver.
        check---
        With the PCL printer driver, toner save mode is set to "Off" by default.
        The toner save mode may be set to "On" --change to "OFF"
        post a PG10 TEST PRINT
          • 16083
          darken the output when printing a grayscale using a PCL driver
          Click File>Print, makes sure you choose the correct Canon printer. Go to Properties>Quality tab> Select Graphics>Press details>change Graphics Mode to Raster and make sure rendering rate stays at 24 BPP then press OK. Check the Manual grayscale Settings checkbox and click Grayscale Settings…Set Brightness to Dark. In addition, setting Contrast to low darkens the grayscale some more. Press OK, OK and Print.
          Note: In order to make the grayscale settings to work, Graphics mode should be set to Raster.
          • apollo
            • Mar 2008
            • 191
            thanks for the reply will visit customer and give you update.
            all PG test are fine PG10 PG6 but will get sample copies and print
            thanks
            • apollo
              • Mar 2008
              • 191
              hi
              removed print board clean all contacts
              and also switched toner save mode and copier working.
              thank you for your help
                • 16083
                hi
