Canon IRC-3080 Drum code
  • NSCT
    • Feb 2010
    • 50
    Have a IRC-3080 with 130K copies on it. We replaced all three color drum units last week. Did not have a new black drum, so left the old one in and cycled up the machine with the 3 new color drums installed. The machine ran okay showing no error codes. Went back a couple of days ago and installed the new black drum. Machine cycled up after black drum install and ran fine. After mach sat idle for a short time the red error message started flashing. The error shows to Insert drum cartridge black and magenta. I shut the mach down and powered it back up and the error message cleared. The mach ran fine for a couple of days. Now the error flashed back up showing Insert drum cartridge black and cyan. This time the error will not clear. Tried resetting all the new drum units. The service mode shows all four new drums reset back to 1%. Any ideas? Thanks for any and all help.
  • doktor
    • 214
    Re: Canon IRC-3080 Drum code
    Try !irc3380-034.pdf
    • Canuck
      Tech Specialist
      • 1713
      Install newest software. If that dont fix it replace the itb assembly. This will take care of it. Drum detection on these machine is determined by transfer charging voltage. If itb is older,it will think no drum. Had many of these calls.
      • teckat
        • 16083
        Make sure u have the latest Firmware as posted
        also-------see----
        If you have replaced the drum units and still have this issue suspect a connection to the ITB unit.
        also-------------------------
        a. Clean the Transfer H.V. PCB (HV2) Contacts.
        b. Clean the Process Unit contacts to the main frame.
        • apollo
          • Mar 2008
          • 182
          I had the same issue and if updated with latest firmware v66.02
          resolved issue
          thanks
          • northernlife
            • Sep 2011
            • 847
            I still get the insert black drum messages even with dcon ver 66.02. apparently it drum detection was supposed to be removed starting with 61.01 but this doesn't seem the be the case.
            • teckat
              • 16083
              old news below -----------but have see a few of these issues
              The conductive bushing on the front side of the ITB assembly for the transfer roller becomes cracked.
              This part cannot be ordered. Replace the ITB assembly. Part number FM2-5522-030.
              ITB UNIT IS CHEAP
              problem could be related to a broken, loose, or missing drive drum coupling.
              In this case the drum drive coupling was dislodged from the black drum drive shaft. This prevented the drum from rotating and caused the machine to display that the drum was not installed.
              • northernlife
                • Sep 2011
                • 847
                Even with new itb's, drive and everything. I still get them. At least they're EOL now so it won't be a problem for much longer. It's the only thing that's been kicking my ass on the canon's.
                • NSCT
                  • Feb 2010
                  • 50
                  Originally posted by doktor
                  Try ![ATTACH]23134[/ATTACH]
                  Got the firmware loaded today. The mach seems to be running fine now. Thanks much for all of the help. Much appreciated.
                  • cda7566
                    • Apr 2014
                    • 2
                    Where can we download a firmware upgrade
                    dcon ver 66.02
                    and system software upgrade.
                    can I have the link, please.
                    thank you.
                    • Jaycat718
                      • Oct 2013
                      • 70
                      dcon ver 66.02
                      thank you.
                      You can download the newest firmware from the canon support site, and use the SST.
                      • teckat
                        • 16083
                        membership id
                        password
                        (needed) :+/
                        • Jaycat718
                          • Oct 2013
                          • 70
                          if it's membership information you want, i do not have it. What i do have, is a special set of firmware. (Liam Neeson Taken impersonation)
                          Pm me.
                          • dgs2006
                            you must have service label or print it from service mode, then execute <dc-con clear> from service mode (level 1), after restarting maсhin restore all values from service label in service mode (levels 1 and 2)
                            as a way...........
                            • urrutiacar
                              Pm me.
                              Hi dear, I am with firmware problems in my printer and I need what I need to continue working with it. If you had the signature for the irc3080i canon printer, I would appreciate it. my email is urrutiacar@gmail.com
                              Thank you.
