IR5000 Warming up too long
  • vins
    • Oct 2013
    • 18
    Re: IR5000 Warming up too long
    Originally posted by northernlife
    You can trip the interlock for the front door and you can see the lights in the fuser come on and off by the way. AC Driver in my experience has always given an e00x code. The only time I've had this sympton the fixing/feeding connector on the machine side was broken. That severely sucked to change. They did modify the connectors at one time.
    i just checked, both lamps are on. i saw it by opening fixing motor cover
    AC driver broken ? where is it's place ? thank you
      • 16083
      The control system makes use of the following signals:
      [1] Fixing roller temperature detection signal 1; M-TEMP [1] generates a voltage suited to the temperature
      detected by the main thermistor.=DCPCB
      [2] Fixing roller temperature detection signal 2; S-TEMP [2] generates a voltage suited to the temperature
      detected by the sub thermistor.=DCPCBSUB_HT_ON [3] the sub heater turns on.DCPCB>AC Driver
      [4] Sub heater temperature detection signal; SUB_DETECT [4] =DCPCB>AC DriverMAIN_HT_ON [5] the main heater turns on.DCPCB>AC Driver
      [6] Main heater temperature detection signal; MAIN_DETECT [6]=DCPCB>AC Driver
      • vins
        • Oct 2013
        • 18
        how much voltage ir5000 need to be operated normally ? is 110 volt or 120 Volt ?
        note : my house electricity 220 v , with step down transformator 220 to 110 volt.
        do i have to raise up the voltage (transformator ) ? 220 to be 120 v ?
        • Brian8506
          • 1665
          #19
          Have you monitored the warmup in sm copier/display/analog? If those lamps are on it should get to about 200C in much less than 15 minutes. If anybody knows the exact warmup time, jump right in.
          • vins
            • Oct 2013
            • 18
            #20
            start up > after 2 minutes got error e00002 > clear error > 13 minutes include warm up time > normal temp reach 200 C (i see it in copier/display/analog)
            so.. total time about 15 minutes the machine got ready to make copy
              • 16083
              #21
              ______________::__
              Signal & Voltage Supply \ didn't u see the chart
              DC pcb \ AC Driver
              Did u check & monitor your wall voltage into printer> and out the pcb's ?
              Simple troubleshooting steps (;>
              • spectraindo
                • May 2008
                • 313
                #22
                You can not just looking at the light coming out from the lamps, measure both lamps with an Ohm meter to make sure it is not broken, and as someone tells you inspect the connectors, maybe it is broken.
                Also check the voltage coming out the transformer when the machine is ON, should be no less then 110V.
                A normal machine takes 3,5 to 4 minutes to warmup.
                  • 16083
                  #23
                    • 16083
                    #24
                    where is this machine located ?? (Country)
                    is the printer in an area in a business company, & or house/apartment
                    what model 100v/ 120v/ 230v------------
                    make sure thermistors are in full contact to roller surface & not bouncing away during rotation
                    WNUP
                    (warm-up)=
                    INTR
                    (initial multiple rotation)
                    ; this is to even out the
                    surface temperature of the fixing roller.
                    • vins
                      • Oct 2013
                      • 18
                      #25
                      WNUP
                      (warm-up)=
                      INTR
                      I saw the label rear the machine,. 120 - 127 V
                      but my output transformator 110 v, maybe it makes the heater lamp slow to reach 200 C. ?
                      i want to replace my transformator first.. (suitable for 120v)
                        • 16083
                        #26
                        Printer needs to operate on a + \ - of 10% voltage from outlet. The reason for a dedicated outlet means the only item on that line receives proper regulated voltage--
                        Have seen in old buildings floor above & below draw down voltage on same line\ this causes many issues--/ & when people plug in toasters\microwaves\refridgerators/ that draw down voltage
                        • vins
                          • Oct 2013
                          • 18
                          #27
                          the problem is solved.. i changed ac drive and also both heater lamps
                          now my machine warm up 3 minutes
                          thankyou everybody for your replies
