CANON IR2420 damn message !!
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    [Electrical] CANON IR2420 damn message !!
    Hi to all
    i've problem with canon ir2420 , displaying (front\left cover open close cover) i've reset it but no result , have too replaced the 2 switchs (front and left door ) but no result i checked the connextion with continuity circuit between the power supply and the 2 switchs it was good , but machine still displaying this message!!!
    there is some ideas!!!!!
    thank you in advance!
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • mikejose
    • Oct 2013
    • 35
    Re: CANON IR2420 damn message !!
    Sounds like it could be a bad photointerrupter on one of the doors. I had a similar problem on an IRA c5030.
    • sweet.persona
      Engineer
      • Nov 2009
      • 414
      thank u friend but i have replaced new 2 interrupteur ( for the front and left cover) but No result!!
      DAMENE ABDEL AZIZ
      DJELFA
      • Mr.Claire
        • Mar 2008
        • 49
        This may sound stupid, but is the machine level... Is the flag actually breaking the beam path?
        • sweet.persona
          Engineer
          • Nov 2009
          • 414
          what m&an for the beam path! there is just simply switchs! in the front and left cover!
          thank you in advance.
          DAMENE ABDEL AZIZ
          DJELFA
          • Mr.Claire
            • Mar 2008
            • 49
            I've just seen machines with door switch problems that were because the machine not being level. The door flexing therefore the actuator on the door does not fully hit the sensor in the machine that you have already changed. Its just a suggestion.
              • 23009
              The way a photointerrupter works, is that an LED shines light through a slit across to a photorecepter which changes voltage from low (~0) to high (~5vdc). The flag blocks the beam path so that it does not shine on the photoreceptor ... or it should block the light. The flag may not adequately block the light path, so the sensor does not change state.
              I wonder how this will translate?
              Try that:
              الطريقة التي يعمل لphotointerrupter، هو أن الصمام يضيء الضوء من خلال فتحة عبر لphotorecepter الذي يتغير من الجهد المنخفض (~ 0) إلى الأعلى (~ 5VDC). الكتل العلم مسار الشعاع بحيث لا تشرق على مستقبلة للضوء ... أو ينبغي أن منع الضوء. العلم قد لا منع كاف مسار الضوء، وبالتالي فإن استشعار لا يغير الدولة.
              Courtesy of Google Translate.
              • teckat
                • 16083
                continuity circuit
                Did u check for correct voltage supply
                is the power supply outputting 24VDC out of J12
                NOTE:
                If 24VDC is found at J12 on the power supply, check the DOPEN signal at J215, pin 7 on the DC Controller to be sure it changes state.
                Open and close the door, to check the signal. If the signal changes state, replace the DC Controller
                SW2 /Front cover switch Detects opening/closing of the front cover.
                Detects opening/closing of the front cover and cuts off +24 VR.
                Power supply PCB=J12
                SW3 /Left door switch Detects opening/closing of the left door.
                Detects opening/closing of the left door and cuts off +24 VR.
                When the main power switch (SW1) is turned on, AC power is supplied to the low-voltage power supply circuit in the power supply PCB.
                low-voltage power supply circuit supplies +3.3 V, +5 V, and +24 V to operate the machine.
                There are two types of +24 V voltages: +24 V which is normally supplied from the low voltage power supply and +24 VR which is cut off when the front cover or the left door is opened.
                The +24 VR also plays the role of a door open detection signal (DOPEN).
                This signal allows the CPUon the DC controller PCB to detect that the front cover or the left door has opened.
                Power Supply PCB is provided with an over-current/over-voltage protection function to automatically cut off the output voltage when a trouble such as a short circuit occurs on in the load.
                • sweet.persona
                  Engineer
                  • Nov 2009
                  • 414
                  thank you to all
                  i found bad resistance ( in the J12 track - power supply ) it displaying just 8 Ωand it's low value!!!!
                  i replaced new resistance and it is okay now ! thank you very much for all our great Engineers!!ouuoo_10.jpg
                  DAMENE ABDEL AZIZ
                  DJELFA
                  • teckat
                    • 16083
                    thank you to all
                    i replaced new resistance and it is okay now ! thank you very much for all our great Engineers!![ATTACH=CONFIG]23542[/ATTACH]
                    Macgyver.jpgWOW / haven't done a field replacement on a small component since 1991
                    • Mr.Claire
                      • Mar 2008
                      • 49
                      Originally posted by teckat
                      [ATTACH=CONFIG]23543[/ATTACH]WOW / haven't done a field replacement on a small component since 1991
                      I was thinking the same thing, but about 1995...
