hi evrybody..
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    hi evrybody..
    hallo evrybody l have code e065 in copieur canon 6028 . can you healpe me to rasult this problem ..or send me pdf technical. my e-mail: mecanopharme@hotmail.fr.
    BEST TECHNICIAN . NICE PEOPLE .
  • kwazimoto
    • Jan 2007
    • 199
    well i think you are working on a NP 6028 witch is the same as a NP 6030 the error code if for the transfer roller witch is under the drum unit...you can clean it really really good, or replace it is what it noramlly is but if it is not that check your static eliminator,high voltage termals,or composite power supply...hope this helps..
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      thank's ..
      dear technician kwazimoto thank you very mutch for you assitance
        • 23002
        Actually it translates ito a NP-6035/ NP-6230, but the meaning of the code is the same. The differences in the models is minimal.
        • lkrsardis
          • Dec 2007
          • 316
          e65
          Also check the transfer roller connector for arching if not that the composite power supply is bad.
          Like the United States Postal Service It's a miracle it works!
          • zaza
            MECANOGRAPHE
            • Mar 2008
            • 1095
            thank's.
            dear technician thank you very much for your assistance technical but l need the pdf technical with you ...if anyone have please send me that for : mecanopharme@hotmail.fr
            • xcopytech
              • Aug 2006
              • 1794
              here is error code description from 6035 service manual
              • zaza
                MECANOGRAPHE
                • Mar 2008
                • 1095
                thank you lot
                hi dear xcopytech thank you for you send me this pdf .
