hallo evrybody l have code e065 in copieur canon 6028 . can you healpe me to rasult this problem ..or send me pdf technical. my e-mail: mecanopharme@hotmail.fr.
hi evrybody..
well i think you are working on a NP 6028 witch is the same as a NP 6030 the error code if for the transfer roller witch is under the drum unit...you can clean it really really good, or replace it is what it noramlly is but if it is not that check your static eliminator,high voltage termals,or composite power supply...hope this helps.. -
thank's ..
well i think you are working on a NP 6028 witch is the same as a NP 6030 the error code if for the transfer roller witch is under the drum unit...you can clean it really really good, or replace it is what it noramlly is but if it is not that check your static eliminator,high voltage termals,or composite power supply...hope this helps..BEST TECHNICIAN . NICE PEOPLE .Comment
Actually it translates ito a NP-6035/ NP-6230, but the meaning of the code is the same. The differences in the models is minimal.
=^..^=If you'd like a serious answer to your request:
thank's.
here is error code description from 6035 service manualAttached FilesComment
