iR5185 sub-scanning color registration shift
  • Toner Boy
    • Aug 2007
    • 365
    We replaced the ITB belt, drive gear, swing plate, did not fix until we went into Sevice Mode 2 and cleared REGIST, performed Gradation Quick, then Full Adjust - perfect pages. Now it is reported the problem is back. Any thoughts? I doubt the pattern reader would be causing this issue but not sure. 1mm shift in colors for paper travel direction. No skew, vertical offset. Have switched with another ITB unit, same issue.
  • copier tech
    • 8142
    Re: iR5185 sub-scanning color registration shift
    I've had the same issue in the past. For me I did a DC con clear, then re-entered the settings from the P-Print out fault never came back.
    • canonbundy
      • Jun 2012
      • 607
      Try without Quick Grad then reboot, I have found it needs to be done sometimes 3 or 4 times.
      • tinnyjay
        • Oct 2009
        • 663
        I would change transfer rollers for each colors.
        "Who loves the roses,must also bear thumbs"
        • Toner Boy
          • Aug 2007
          • 365
          When we went back the images were fine, but samples they had proved it was misbehaving again. Performed Full Gradation Adjust again (4 times for good luck) and instructed end user of adjustment procedure. Crossing fingers for now...thanks for all the replies. Did not do DC-Cont clear yet, don't want to if don't have to.
          • Canuck
            Tech Specialist
            • 1713
            Remove the itb. Scrub the hard rubber rolls(secondary internal transfer and belt drive roller.) Make sure that the secondary external transfer roll(the one in the fixing drawer) turns freely. Remove it and clean its supports(contacts,etc). If this roll is stiff to turn it will cause itb to slip,causing misreg
