Canon Y2 Saddle finisher Error E542-8002
  • vamoursly
    • Sep 2011
    • 273
    [Error Code] Canon Y2 Saddle finisher Error E542-8002
    Hello
    I have a Canon Y2 Saddle finisher with error code E542-8002
    I only get the error when printing or copying to delivery tray B
    I bought a SM for it, anyone seen this issue?
    Code Detail Error Description Detection timing
    E542 8001 Tray 2 shift motor
    (M108)/Tray 2
    shift area sensor
    PCB
    If the tray does not return to home position when
    the tray 2 shift motor is driven for 20 seconds.
    If the tray does not move to other area when tray
    2 shift motor is driven for 4 seconds.
    8002 When reached to the upper limit area before the
    paper surface sensor detects paper surface during
    the paper surface detection operation.
  • copier tech
    • 8235
    Re: Canon Y2 Saddle finisher Error E542-8002
    Very common fault on that finisher. The flag breaks.
    Are you sure your code is not E540-8002?
    TP12 126a.pdf
    • tinnyjay
      • Oct 2009
      • 666
      Originally posted by vamoursly
      Hello
      (M108)/Tray 2
      shift area sensor
      PCB
      You have the problem solved if you have a SM(if u r a tech)
      Find by the Service manual where is located shift sensor area(it detects the rotation of motor M108.
      "Who loves the roses,must also bear thumbs"
