error code E355 - 0004
  • mubiz
    replied
    Re: error code E355 - 0004
    Thx Teckat. yeah, its just a iR1133 just as in Canon IR1133. it does not have that interface. My buddy and i opened it to the inner board and tried to refit all fibres and other connections, but nothing changed. The fact is that i cannot access the menu/ or service code. Its in Chinese and upside down. Any other alternative? Its as if the control panel buttons are all mute. cant find any button responding or it should first be the service button (*) to respond first? I am puzzled. Please help. thanks.
    replied
    is that iR1133 an imagePress Series model or just a iR1133
    was there any work performed on this model before E355-004 ERROR
    Try Re-fitting all the harness connections within the control panel assembly
    do u see a Language Switch Shortcut Key- on the display ??
    Language Switch Shortcut, when enabled, is displayed next to the 'System Monitor' button on the device LCD screen as shown in the image below. It allows users to walk up to the device to quickly and easily switch the LCD display to their desired language. This shortcut can be useful if, for example, the device is located in a hotel's business center where people from all over the world want to access the device.
    Configuring the Language Switch Shortcut Key
    1. Go to Additional Functions / Common Settings / Language Switch and the following screen will appear:
    FIGURE 2
    2. Press ON
    3. Select a default language
    4. Select 'Display Shortcut Key' (when this option is selected the button will change from gray to teal in color)
    5. Press OK
    II. Using the Language Switch Shortcut Key
    When a user wants to change the display language they have to click on the Shortcut Key, as shown in figure 1 above, which will bring them to the 'Language Switch' screen, as shown in figure 2 above. From here they select the desired language by highlighting it from the list and press OK. This will return them to the copier main LCD screen where all buttons and text will be displayed in the selected language.
  • mubiz
    started a topic [Error Code] error code E355 - 0004
