Canon ir5870
  • teckat
    • 16083
    #31
    Re: Canon ir5870
    Originally posted by akhait01
    so i checked all of the toner bushings and found no problems. any other idea on why im getting these error codes?
    http://www.ebay.co.uk/itm/Canon-IR58...item2ec64b238a
    Used: An item that has been previously used. The item may have some signs of cosmetic wear, but is fully operational and functions as intended. This item may be a floor model or an item that has been returned to the seller after a period of use.
    • akhait01
      • Apr 2011
      • 58
      #32
      Re: Canon ir5870
      These are the following parts that are out of their life span.
      TRD-CLN
      TR-BLT
      TR-ROLL
      2TR-ROLL
      TR-STC-H
      1TR-STC
      ITB-SUPS
      CLN-BLD
      CL-SUPS
      Any ideas??
      • teckat
        • 16083
        #33
        Re: Canon ir5870
        TRD-CLN
        TR-BLT
        TR-ROLL
        2TR-ROLL
        TR-STC-H
        1TR-STC
        ITB-SUPS
        CLN-BLD
        CL-SUPS
        Any ideas??
        TRD-CLN= Transfer drum cleaner------------------150,000 prints
        TR-BLT= Transfer belt unit------------------------300,000 images-/ in the case of a black mono color print, counted as 1 image; in the case of a full color print, counted as 4 images.
        TR-ROLL= Secondary transfer outside roller--------150,000 prints
        2TR-ROLL= Secondary transfer static eliminator----150,000 prints
        TR-STC-H= Primary transfer static eliminator-------300,000 images-/ in the case of a black mono color print, counted as 1 image; in the case of a full color print, counted as 4 images.
        ITB-SUPS= ITB cleaner scoop-up sheet-----------150,000 prints
        CLN-BLD= Cleaner blade--------------------------250,000 images-/ in the case of a black mono color print, counted as 1 image; in the case of a full color print, counted as 4 images (one edge in use)
        CL-SUPS= Cleaner scoop-up sheet----------------250,000 images-/ in the case of a black mono color print, counted as 1 image; in the case of a full color print, counted as 4 images
