Canon ir5870
  • akhait01
    • Apr 2011
    • 58
    Canon ir5870
    Hello Everyone,
    I am seeing black spots in random spot on prints. All help is greatly appreciated.
  • northernlife
    • Sep 2011
    • 847
    Re: Canon ir5870
    Looks like the black dev is leaking
      • 16083
      Re: Canon ir5870
      Originally posted by akhait01
      Hello Everyone,
      Random black spots on copy
      Copies and prints have random black spots.
      The spots may be caused by a worn mylar in the ITB Cleaning Assembly ( Transfer Cleaner Assembly ). There is no part number assigned to the mylar, therefore the ITB Cleaning Assembly must be replaced.
      ITB ( Transfer Cleaner Assembly ) PN: FM2-0522-000
      • akhait01
        • Apr 2011
        • 58
        Re: Canon ir5870
        How do I check that?
          • 16083
          Re: Canon ir5870
          take it out------------------------
          but first -----Removing the ITB Cleaning Unit
          get a manual-----------
          • dan7777
            • Dec 2012
            • 680
            Re: Canon ir5870
            I agree, ITB cleaning unit.
            • akhait01
              • Apr 2011
              • 58
              Re: Canon ir5870
              Ok thank you. Will post results.
              • Canuck
                Tech Specialist
                • 1713
                Re: Canon ir5870
                The spots are more crap colored than black...lol.. SPOT black from dev would be pure black...crap colored is waste toner from itb cleaner. Mylar out of position in cleaner or something as mentioned.
                • akhait01
                  • Apr 2011
                  • 58
                  Re: Canon ir5870
                  Ok seems like the replacement of its cleaner fixed one problem but here are the other issues I have found in the images.
                  • akhait01
                    • Apr 2011
                    • 58
                    Re: Canon ir5870
                    Can anyone help me or give me an idea of what the heck is going with thiis printer. I'm stuck and any help would be greatly appreciated. thanks again
                      • 16083
                      Re: Canon ir5870
                      first i need to gut the printer (remove all assembly's) and inspect/clean interior
                      Poor environment can cause electrical discharge between the primary transfer roller and the primary transfer static eliminator
                      Faulty Color Reproduction Caused by an Error in Primary Transfer ATVC
                      can adversely affect color reproduction.
                      perform---a
                      COPIER>FUNCTION>MISC-P>ITR-ROT
                      MAINTENANCE IS NEEDED
                      waste toner dropped from the Drum Cleaning Unit /did u check this
                      -Replace the Cleaning Brush with a new one
                      When performing replacement of the cleaning brush, check both of the gears for breakage. If they are broken, replace them with a new one.
                      Inspect,the teeth of the 24T gear and the 54T/18T gear-
                      1-next is u need a full developer change or replace dev units
                      2-replace transfer belt
                      3-Check the Primary / Grid> Replace
                      4-Drum Cleaning Blade=replace it
                      • akhait01
                        • Apr 2011
                        • 58
                        Re: Canon ir5870
                        I don't understand it though... As soon as I replaced the itb cleaner this had happened. I haven't replaced anything else on it just the itb cleaner. Could it be that the itb cleaner that i installed is defective?
                        UOTE=teckat;406671]-------------------
                        perform---a
                        4-Drum Cleaning Blade=replace it[/QUOTE]
                        • Gamut
                          • 216
                          Re: Canon ir5870
                          Toner build up in the ITB cleaning unit falls onto the supporting frame, when you cleaned/replaced cleaning unit you possibly knocked toner onto the transfer roller below.
                          Take out ITB cleaning unit again, also yellow drum unit, pull Itb assembly out from r/h side and shine torch into gap that yellow drum came from, use vacuum cleaner to remove all toner spilt.
                          Then pull out fuser draw from l/h side and clean transfer roll.
                          Refit all parts run up machine and sit down with a nice cup of Tea..........
                          • akhait01
                            • Apr 2011
                            • 58
                            Re: Canon ir5870
                            ok so I removed all units cleaned them out with compresed air, installed back everything and then the printer tells me that cyan and magenta toner is out. I'm thinking this was the whole problem to start with, the printer was not recognizing that those two toner cartridges were empty. That is why the color was printing very light. At least I'm hoping that's what the problem is. I ordered cannon toner will let you guys know in couple days. Thanks for all of your support.
                            • vigour
                              • Aug 2010
                              • 1038
                              Re: Canon ir5870
                              Is your problem the big light oval spots , or are you trying to show that the prints are light ?
                              If you are trying to fix the spots, make single colour PG5 test prints, to narrow dow where the problem might be.
